Congrats and welcome (but yeah, maybe a more direct question next time
Van looks neat - I'm always attracted to those sort of industrial/transformer looking interiors.
One note from something I saw in the ad:
"I added 2 Captain Chairs (Driver and Passenger from a 2009 Ford Econoline, after that the airbag light stayed on. Not sure what is causing this, it worked before I swapped out the seats."
I don't know if you know this or not, but at least on my 1997, if the airbag light is on, that means the whole system is disabled - so no airbags in a crash. If that'd be fine with you, no big; but I just thought I would mention it in case you were not aware.
You may see a series of flashes when you first start the van. If so, that's a clue. It will be a pattern of two "digits" (at least is on my '97), repeated three times, then the light comes on solid. The codes are different from OBD codes, but you can look them up online.
I'd want to get that working again.
