08-24-2015, 09:53 PM
If you need something like this ...
... here's one of these.
From Craigslist in Mendocino County, Californy..
http://mendocino.craigslist.org/cto/5146541988.htmlhttp://mendocino.craigslist.org/cto/5146541988.html
COPY READS:
1995 F 350 chassis with a 95 12 valve Cummins but has been turned up. with bigger turbo piping and Industrial injectors, fast fuel pump ,4 inch straight pipe all the way back with six inch tip .with a new rebuilt 4 speed Allison transmission with p.t.o. auto still under warranty maybe 1500 miles on it.has air system with train horn ,air ride seats ,new airbags and it has a Jake also. gooseneck ball in the bed and a 5th wheel hitch .full sleeper couch folds down into a bed, DVD player and LED lights all over inside and blue ones behind the grill , fog lights.100 gallon fuel tank. New tires,new brakes all the way around,new wheel bearings and tie rods and alignment,new batteries .and new master cylinder,Rhino lined bed liner,no fluid leaks whatsoever , new radiator and overflow tank,new shocks, new air compressor ,new starter, fresh oil change and fuel filters .low miles 150xxx
(Not mine, no affiliation)
