Old 07-11-2013, 01:07 PM   #1
Viejo's Avatar
Locking Diff - air or electric? ... and why?
I'm thinking of getting locking diffs, on the rear at least. Should I be looking at air (ARBs) or electric (Eaton)?
Electric seems to win on cost, ease of instillation and use. What am I missing?
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 07-11-2013, 01:42 PM   #2
E350's Avatar
Re: Locking Diff - air or electric? ... and why?
IIRC, you will be limited by your rear axle. If you have a semi-floating axle, I believe, that only the ARB will work. If you have full-floating axle, all options are available to you.
Old 07-11-2013, 01:47 PM   #3
My observation has been electric lockers are very reliable, while air lockers occasionally have leaks. Also, electric lockers are self-contained (moot point if you already have on-board air). But air lockers are available for many more applications.
Old 07-11-2013, 04:23 PM   #4
BajaSportsmobile's Avatar
Why? Where do you go that you need one?
Old 07-11-2013, 05:03 PM   #5
Since when is anything on our vans driven by "need"
Old 07-11-2013, 06:56 PM   #6
I was advised by John as SMB West (2006) to go with limited slip diff in the rear, and a locker in the front. I don't do heavy duty boulder scrambling, but wanted to get up over ledges, and better pulling power in snow and mud. I wend with the ARB Air Lockers.
2006 EB 6.0 Diesel, custom gaucho,
Espar hydronic and heat, 2 Solara panels,
Trojan F&R, ARB lockers, Warn winch.
BACKRDS is offline   Reply With Quote
Old 07-11-2013, 07:20 PM   #7
I always lusted after an Ox locker, but I don't think they make one that would work for an E350. Cable actuated, but I think they offer electric and air actuated options.
http://www.ox-usa.com/ox/
BroncoHauler is online now   Reply With Quote
Old 07-11-2013, 08:51 PM   #8
Hell, it doesn't have to be that bad to make a locker a pretty nice thing to have. Sand, snow, gravel, mud... anything that gets the wrong two wheels slipping can mean digging or pulling out where a locker would keep you going.
Old 07-11-2013, 09:34 PM   #9
rionapo's Avatar
We chose front lockers on the advice of a friend who was part of the company that brought G-Wagons to the US before Mercedes bought them out. His example was crossing a stream w/rear wheels on slippery rocks and a rocky exit. The added pull we'd get from the front end would help get out.
Fresno's 1st 2012 Ford van.
RB E350 6.8L V-10 4WD w/Front Air Lockers
PH Top, Kyocera solar with Zamp portable unit
(If we'd bought the winch, we'd make a fortune pulling cars out of the snow.)
-Don-
Life and baseball both sometimes are not fair, but it is how you play the hops that counts.
—Scott Miller, NYT Sports
rionapo is offline   Reply With Quote
Old 07-11-2013, 11:06 PM   #10
Tapatio's Avatar
Went with front and rear ARB. A compressor is a must have so it was an easy decision for me. Nothing exceeds like excess.
Callsign KK6GIY
