Old 03-24-2014, 09:33 PM   #1
7.3 Any external noise reduction options?
Hello all,
Long time lurker but new member.
I've had gas vans in the past and I've put 100K on my 03 7.3 SMB so I don't need to be sold on the pro's and cons of both...... with that being said I like to spend my time in the back country and it kills me to go roaring up the mountain. With all the engineers on this forum I'm hoping some clever obsessed SMB'r has figured out some tricks that will help.
Bio Diesel: yep that helps
Dynamat for the interior: check
Tuner? Since I'm looking for mostly low RPM crawling up the mountain noise reduction I'm not sure about that one.
I know it's a bit of a long shot but I'm looking to improve my SMB back country experience.
Thanks in advance.
Mountainair is offline   Reply With Quote
Old 03-25-2014, 12:35 AM   #2
schluchtenflitzer's Avatar
Re: 7.3 Any external noise reduction options?
Maybe a torque converter clutch switch would be a good idea. Specialy go up the mountains it is a great option. The engine is not turning with high rpmīs and produce a lot of noice only to heat up your tranny oil.
The 7.3 has so much torque.....after getting moving i always use the switch and i f i need i shift by hand.
Attenting to this your mpg will rise up ;-)
For inside noice it is very importand to seal up the dog house very well. Mine had a small leak and that causes the noice inside rising up like hell.
www.Dieda-unterwegs.net
Old 03-25-2014, 06:15 AM   #3
shenrie's Avatar
ive seen people on here mention additives that they used to help quite down the 7.3, but i cant find the thread where it was mentioned. maybe someone else knows and can chime in??
im with ya though, id love to be able to quiet mine down some if it was possible.
Old 03-25-2014, 09:22 AM   #4
There's not a whole lot you can do on an older diesel.
If you don't have split-shot injectors (CA-approved vans) then adding them can reduce the clatter, as this was the first attempt at any sort of "pilot-injection". Turning down the injection pressure can also reduce clatter at the expense of efficiency. Cetene booster can also help in some situations too (biodiesel already burns a little slower, so adding it to that fuel probably won't help).
That said.... any quietness gained on a 7.3L probably won't really be noticeable unless you are next to another 7.3L.
Old 03-25-2014, 09:40 AM   #5
dhally's Avatar
What did you say?
2009 E250 RB 5.4L "SilVan"
Old 03-25-2014, 10:27 AM   #6
Originally Posted by dhally
What did you say?
Glad to see in not the only smart ass. I was going to post a pic of a V10 engine but got lazy.
Old 03-25-2014, 11:55 AM   #7
Viejo's Avatar
Being nearly deaf does have the occasional advantage.
Turning off my hearing aids quiets that beast right down.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 03-25-2014, 12:01 PM   #8
rockbender's Avatar
Wrapping the exhaust is a double edged sword since it can tend to rust things up quicker by trapping moisture, but I've heard it can help.
I also believe there are some sound dampening kits for your hood that may help as well. Does your hood still have the stock noise barrier / dampener material?
Josh
Old 03-25-2014, 12:02 PM   #9
buckkiller's Avatar
Man the sound is what I love!! No other diesel sounds like a 7.3 period the Cummings sounds "cute" next to it..:P
My advice "EAR PLUGS":mrgreen:
Buck
"The Redneck Mexican"
2002 E350 EB 7.3 Clydesdale 4x4 w/8' lift,
Colorado Camper Van pwr top,
Van Specialties build out
buckkiller is offline   Reply With Quote
Old 03-25-2014, 10:31 PM   #10
[quote="schluchtenflitzer"]Maybe a torque converter clutch switch would be a good idea.
There's one I haven't thought of.... I'll have to check it out. THX
