Old 05-26-2014, 07:30 AM   #1
alta825's Avatar
Used 6.0's w/ replaced engine?
In looking for a another used 4x4 SMB, I am seeing a few 6.0s out there w/ a Ford Warranty replaced engine. Thoughts on these? For ex, there's currently a couple on the SMB Preowned page w/ 11k or so on the new(er) engines.
If they were replaced with a more current engine from Ford Warranty, anything I should be aware of or should I stay away?
Thanks for the input -
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 05-26-2014, 07:49 AM   #2
Re: Used 6.0's w/ replaced engine?
Engine-wise I wouldn't worry about it, provided the engine was replaced under warranty. If it was replaced not under warranty, I might be concerned the engine had to be replaced because of a lack of proper maintenance. If you can get the VIN, and see if one of the Ford techs on some of the other forums can run an OASIS report for you, that should tell you why the engine was replaced.
I would be sure to make sure all the SMB installed options work, since the body was probably removed to swap the engine.
Behemoth
Besags
Jiminy
Gooseberry
