Old 06-29-2014, 11:38 PM   #1
severe battery issues.
Have an '04 6.0 diesel. Was on the way home from a trip today and got stranded 1 mile from home (lucky). I stopped and turned off the ignition, and when I went to fire it back up, the dash lights flickered and the gauge needles kinda had a seizure. Then I had no power and the van wouldn't start. Wouldn't even turn over. Nada. I tried jumping, and with a good ground, I got some clicking, but that's it. The start batteries are brand new and I'd been driving for 5 hours so they should've been sufficiently charged.
Also, I think my aux battery is bad, so I had turned off the inverter/charger for the whole trip and didn't use any 12v or 120v accessories for the trip. I also had disconnected the separator for the trip so the aux wouldn't charge while driving (It was giving off an odor and getting hot and I didn't have time to take it out).
Any ideas?
ecmccarthy is offline   Reply With Quote
Old 06-30-2014, 12:08 AM   #2
Severe battery issues.
Also, when the dash was freaking out, a warning message came up that said "water in fuel". Would this have anything to do with engine shutdown?
Old 06-30-2014, 09:09 AM   #3
Re: severe battery issues.
My batteries went down while driving when my alternator failed. Bad news is that low batteries can be hard on the FICM and that can kill injectors.
Good luck,
Old 06-30-2014, 01:27 PM   #4
WhitH's Avatar
My alternator is on its way out, I'm scheduled to have a high output one put in this Wednesday. I've been keeping an eye on voltage with my Scangauge and trickle charging at night. Even if you don't have a Scangauge your dash light should've come on if youre alternator was performing poorly enough to let your batteries die that quickly.
Sold 2005 E350 Chateau
Old 06-30-2014, 02:37 PM   #5
Tapatio's Avatar
The starting batteries are in parallel. If one battery developes a shorted cell, it will drag the good one down with it. Did you replace both of them? I would drop the batteries and check them out along with the wires.
Callsign KK6GIY
Old 06-30-2014, 03:19 PM   #6
twogone's Avatar
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 06-30-2014, 06:41 PM   #7
This was me 6 months ago - monitoring scan gauge, trickle charging... got the HO and things are peachy. My batteries were not ruined but they never completely cycled like possibly happened to the O.P. All of our 6.0's are now on the 3x / year plan... plan on a major expense every 4 months!
Pat
Old 06-30-2014, 07:52 PM   #8
UJOINT's Avatar
Yes, check the batteries but also check the main ground behind the batteries. See if its loose, tighten it up if needed.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 06-30-2014, 09:37 PM   #9
Having an amp meter can also help figure out what's going on. High amp flows that never taper off while charging usually indicate a bad battery in the bunch. Some inverters have an amp meter built in but you need to know what is a normal charge rate.
Don't let Ford check your batteries, rather have somebody drop each battery and do a load test on each of them on their own. And yes, always check the connections as mentioned. If your alternator is going out the amp meter will show minimal flow but the voltage can also go high and low. A good electrical shop probably does a better job at troubleshooting than your dealership but there are dealerships that shine if they go beyond what Ford mandates as procedure.
BTW, Surepower separators do run kind of warm normally. If you completely isolate the house battery and put a good charge to it, let it sit for 48 hours and check the voltage. A good battery should read 12.8, an OK battery will read 12.5 or 12.6, and anything lower is on its way out.
Old 07-11-2014, 03:39 PM   #10
Thanks for all the input. A trusted mechanic has told me that he thinks it's the alternator. With the van running, it's putting out 11.5 or so volts. The start batteries are less than a year old and were both replaced at he same time under warranty from Ford.
I know the alternator was replaced by a previous owner. It was put in by Ford and I don't know what amperage it is, however, based on the fact that Ford installed it, it's probably a 110 or 120.
I want to put in a 200 or 220 amp alternator. Any suggestions on a source? Also, Ford tells me that if I did that it would need to be rewired. My mechanic says no. Any thoughts? Wouldn't the original build from Sportsmobile have included a larger output alternator, and thus, sufficient wiring for it?
