Old 08-20-2014, 12:59 AM   #1
Nick's Avatar
More brake questions
Time to upgrade brakes on my 06 E350 2 WD DSL with 16" wheels. Looking for recommendation on caliper and pads, What best and why?
And thanks
Old 08-20-2014, 04:42 AM   #2
Re: More brake questions
Just last October I upgraded my '03 E250 EB to '08 brakes, used nothing but OEM reman'd calipers direct from the local Ford stealership. Brake hoses also but opted for NAPA's Ultra Premium pads---pretty much same cost as OEM/Motorcraft.
I'm loaded about 7,500# as a daily driver and just over 12K miles the front rotors look almost unused--probably due the NAPA pads.
Old 08-20-2014, 05:59 AM   #3
I've heard nothing but good things about Napa's gold pads too.
Old 08-20-2014, 06:27 AM   #4
Nick's Avatar
Will they fit in the 16" Alum wheels?
Old 08-20-2014, 07:05 AM   #5
There are a few threads here about this swap (I did it, too), that you might want to review.
The 2008+ brakes will fit in OEM 16" alloy wheels, but I don't know about aftermarket ones. I got a set of 2012 OEM Ford aluminum "mag" wheels from the same van I got the front-end/brake parts from.
Old 08-20-2014, 11:26 AM   #6
Nick's Avatar
I was really just thinking about upgrading the rotor and pad with same size.
What the best plug and play upgrade out there.
Old 08-20-2014, 02:00 PM   #7
none of the above
Really. I tried just about every combo before settling on a 2009 axle. The Napa ultra premiums will bite a little better than stock, at the expense of putting more heat into the rotors. I used to crack mine in as little as 6 months.
Old 08-20-2014, 09:41 PM   #8
If I knew what I know now, I'd of gone with 17" rims and the largest stock rotors, calipers and pads. Unfortunately 17" wheels were not really around in 2005, at least ones that held the weight and looks I wanted. But I did a swap to Brakeman rotors, and pads. I've been happy with them but they are a bit overpriced IMO.
Old 08-21-2014, 06:22 AM   #9
REF
REF's Avatar
Send a message via MSN to REF
I went with frozen rotors, cryo and slotted up front, hawk pads and stainless lines all around, Nice upgrade on my 16"
Old 08-21-2014, 08:14 AM   #10
shenrie's Avatar
^^^ which slotted rotors, which hawk pads, and which ss lines? brands & model names (maybe even part numbers if you have that info?) please, im sure it will help out more than just myself
some hawk pads work great, some eat rotors like doritos. i think the hp+ ones are the rotor eating pads, but its been a long time since ive used any of their products.
