Old 03-28-2015, 10:43 AM   #1
Plugs and fuel filter
So....I had my 100000 mile service done thursday: plugs, fuel filter, tranny fluid,etc. Drove it from park city to salt lake, come out of a store and the thing wouldn't start. It's a v-10. It would turnover, but no ignition. Called the dealer and had it towed back to his place. Neither one of us is psyched but I'm sure glad I wasn't a full-tank into road trip, which could have easily happened. Ran perfectly before I took it in but I heard new plugs at 100k was a good idea and that they are difficult to get at, which is why I had the dealer do it. Damn. Anybody got an idea on a cause? I didn't look to see if the fuel filter was wrong or backwards or whatever. Started right up at dealers place, of course. Reputable dealer that has a lot of vans. I guess he will fix it, but I'd like to know what you guys think.......thanks!
Joe
Joe Skrivan
E-350 V-10; Penthouse, Custom Interior
skrivan is offline   Reply With Quote
Old 03-28-2015, 12:27 PM   #2
Re: Plugs and fuel filter
Joe
"has lots of vans"... who is this dealer if you don't mind my asking?
All things being equal - fat people use more soap.
eddyturn is offline   Reply With Quote
Old 03-28-2015, 01:01 PM   #3
I'd rather not name them, yet. Park city ford dealer. I see a lot of quigley 4 wd rigs in his lot.
Joe Skrivan
Old 03-29-2015, 11:48 AM   #4
Did you try goosing the throttle while you crank?
Could be as simple as the fuel mix needing more time to adjust to the changes.
Old 03-29-2015, 03:07 PM   #5
I tried that. Thanks. It's back at dealer and he can't get it to start either. But he's not the technician, just the scheduler guy. Thanks for answering though.
Joe Skrivan
Old 03-30-2015, 04:55 PM   #6
Guy says I need a fuel pump. Does anyone believe in coincidences like this?
Joe Skrivan
Old 03-30-2015, 06:32 PM   #7
arctictraveller's Avatar
If there is no fuel pressure, either there is a electrical fault not allowing power to the pump, or the pump is toast. I've had to install two pumps in the last 12 months. The first one got intermitent and wouldn't start at first but then came back to life. A pressure gauge showed the pressure to be way under spec. Less than 12 months later, the replacement pump went from running fine to zero pressure all at once. I'm hoping for better luck with this one................
Arctic Traveller
KC6TNI
2001 GTRV
Advanced 4wd
Old 03-30-2015, 11:38 PM   #8
How old is the van? I've noticed a stronger correlation with age than with miles. 10 years and they start going out regardless of miles it seems.
Old 03-31-2015, 03:49 AM   #9
Another factor affecting fuel pump life is how often the tank is run less than 1/4 full. Knowing this can greatly reduce its longevity I nearly never let the tank even get to 1/4 before adding at least another 1/4 capacity or more.
My older E250 (2000, 275K miles) has its original pump and although the sending unit has a minor quirk its still humming right along, no issues starting or performance-wise either. It seems some pumps--when treated right---keep on running very well while others fail a bit earlier than expected.
