Old 04-24-2015, 03:37 AM   #1
ArikB's Avatar
Oil filter?
Sorry for the lame question..
2005 Quigley 4x4 e350 super duty
What is this filter and what is the required maintenance
Thank you!
2005 Quigley E-350SD 6.0L
ArikB is offline   Reply With Quote
Old 04-24-2015, 07:42 AM   #2
Re: Oil filter?
What motor do you have?
Old 04-24-2015, 09:00 AM   #3
scatter's Avatar
Re: Oil filter?
External transmission filter. There is no filter in the trans itself, just a screen which is replaceable. Around 2008 Ford changed the transmission pan to a deeper one which allowed for a full internal filter. That was when they dropped the external filter you're talking about.
Scatter
2007 RB50, 6.0
K1WGB
Old 04-24-2015, 09:05 AM   #4
Re: Oil filter?
I replace that filter every 30K miles when I drain the trans pan and refill.
Old 04-24-2015, 10:52 AM   #5
Re: Oil filter?
Well that explains why I don't have one.......2008 E350...Good info.
Old 04-24-2015, 11:20 AM   #6
Zeta's Avatar
Re: Oil filter?
So, conceivably, if one had a deep Mag-Hytec pan, one could install a 2008 filter in one's pan and eliminate one's external filter that rubs on one's front driveshaft if one were so inclined to spend more of one's money on one's SMB?
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 04-24-2015, 11:58 AM   #7
ArikB's Avatar
Re: Oil filter?
Do you have a part# or a link for buying this filter?
Old 04-24-2015, 01:30 PM   #8
Re: Oil filter?
If I were in your shoes (and I am) I would upgrade to the newer pan and improved internal filter. Next transmission fluid change for me. $58 for the pan is a no brainer.
Part #8C3Z7A194B. The filter is: 8C3Z7A098D
And then presumably you can get rid of the old external filter, although that might mean having to modify the lines.
2011 VW TDI Golf for hwy fun
Old 04-24-2015, 02:54 PM   #9
ArikB's Avatar
Re: Oil filter?
Is it the external filter?
http://www.xtremediesel.com/ford-3c3z-7 ... ilter.aspx
Old 04-24-2015, 04:16 PM   #10
Re: Oil filter?
I was referring to buying the newer pan and switching to an internal filter but yes that is the external filter. It can be found for much cheaper here: http://www.dieselfiltersonline.com/ford ... issio.html
Good source for all your filters. The diesel fuel filters alone are ~$50 cheaper than the dealer and they are motorcraft and not aftermarket.
Jnlola
jnlola
Overland Van
TPowell
