Old 10-21-2015, 11:26 PM   #1
How to remove the Fuel Filter to upgrade to Bluespring Mod?
Hey Guys,
I'm attempting to do the Bluespring Mod kit on my 2006 6.0 Diesel and I'm stuck at trying to remove the fuel line to the side Fuel regulator cap. I'm trying to remove or unbolt it but it seems like it's not budging and that the fuel lines will start bending as apply more torque. Does any one know of a good method of removing this "side cap" to install the blue spring? Any help would be appreciated?
Btw, while I'm at this I also removed the EGR valve to clean it and I noticed at the bottom of the EGR "hole" the carbon build up was a little "gooey". Is this a sign that my EGR cooler is going?
ucsundog is offline   Reply With Quote
Old 10-22-2015, 07:18 AM   #2
Re: How to remove the Fuel Filter to upgrade to Bluespring M
Often times, yes. If you do a lot of short cycle driving however (i.e. 1 mile trip each way to the store) than it can simply be condensation. If you start getting codes for the turbo vanes sticking, then that would be another corresponding symptom (small leak causes rust on the unison ring).
Old 11-18-2015, 04:02 PM   #3
I am interested if you successfully installed the blue spring upgrade.
coolfeet is offline   Reply With Quote
Old 11-18-2015, 04:06 PM   #4
SixCardCharlie's Avatar
Same here ^
Also where is the EGR cooler located?!?!
2004 6.0 PSD
SixCardCharlie is offline   Reply With Quote
