Old 08-23-2010, 10:43 PM   #1
6.0 won't start?
Hi All, I just went out to take the van to the mountains for a bike ride and nothing! It cranked great but no hint at ignition. I've had no problems and treat it like a baby. My chip reader says low turbo pressure? All I can find about that does not explain why it won't start? any pointers???? thanks
gregsmith212 is offline   Reply With Quote
Old 08-24-2010, 06:24 AM   #2
Re: 6.0 won't start?
What year?
Had you been driving it prior to the no start condition, ie. was the engine warm already? The only thing I can think of is a low pressure on the high pressure oil system. This will cause a no start. 2005 model years had a STC (snap to connect) fitting on the HPOP that can develop a small leak and will not allow the engine to restart after it's warm.
Just a thought.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 08-24-2010, 06:43 AM   #3
It's a 2006 and no just heading out for the first start of the day. It never missed a beat prior to this? I'm hoping it's just a loose connection someplace and not the beginning of my 6.0 nightmare...... . The worst part was missing out on a nice ride at Kirkwood Mt bike days. thanks for the help
Old 08-24-2010, 03:00 PM   #4
Did you try the crash switch located right of where the passengers feet sit?
I had a similar problem and it was ICP/IPR valve but I would think the reader would show that. Same with cam sensor.
Old 08-25-2010, 12:02 AM   #5
viewtopic.php?f=13&t=2101
Old 08-25-2010, 09:10 AM   #6
I'm out of town right now but I'll check the kill switch when I get home. (how do I go about that?) I'm hoping its something that easy. I'd hate to give my "new set of skis" fund to the ford dealer........
Old 08-25-2010, 01:43 PM   #7
mine is just a push button switch. My guess is it pops out like a GFI button and pushing it back in resets it. It didn't trip but was the first thing I looked at after the engine died.
Old 08-25-2010, 02:32 PM   #8
Here's my no-start saga. Been trouble free, knock on wood, since then.
viewtopic.php?f=8&t=3665&hilit=+tow
Old 08-25-2010, 02:36 PM   #9
Scalf77's Avatar
Here is a diagram of the fuel inertia switch. I believe it pop up towards the top. You just push it back in. I tripped it a couple of months ago doing some work on the van. I was happy that I remembered being told about it previously.
Old 08-25-2010, 11:09 PM   #10
thanks for all the help and ideas. I'm hoping it's the kill switch. I'm thinking it may be that because my only code is a low turbo pressure code. I'm thinking I'd get that code if the engine does not fire and the turbo pressure will not make it up to speed..... got to love the 6.0. (when it works)
Pow Patrol
smb50co
Agnes
alta825
