04-13-2012, 09:10 AM
V10 fuel question
A while back, I was searching for performance mods on the V10 to milk a few extra MPG, and ran across a thread discussing a certain part that fails on the v10 like clockwork every "Xthousand" miles. I thought it was every 50k miles, but I don't remember. From my understanding it was an easy fix and seemed to be electrical? Can anyone point me to the part or thread? I have been looking and looking to try and find it again.
Best,
C.
04-13-2012, 11:36 PM
Re: V10 fuel question
My V10 has well over 100K - No problems, I would also like to know about any failures.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
04-14-2012, 12:01 AM
Starter relay. It's on the fender by the battery. It's about $12 for a cheap one, or ~$22 for a OE one. Bumping the ignition will usually make it go eventually, and if that doesn't work the terminals can be jumped with a leatherman. (Make sure its in park! it overrides the safety switch doing this)
04-18-2012, 11:59 AM
04-18-2012, 05:04 PM
V10 fuel question
CarringB, the starter relay would affect mpg? I have a 5.4 but am still curious.
Thx
04-18-2012, 05:30 PM
Thx
In a word: NO.
If it failed, and you couldn't start your van, it could reduce your fuel consumption however.
04-18-2012, 07:18 PM
Ah, thanks, I think i'm seeing the pattern here.
04-20-2012, 02:26 PM
What is bumping the ignition?
04-20-2012, 05:48 PM
Turning the key to the START position. Repeat until the solenoid engages the starter.
04-20-2012, 05:59 PM
I have had two vans with the v-10's. No problems at all. I have been very happy with both. My first van had 177K on it when I sold it. It ran solid the entire time with no problems. Have 68K on my current one and it been bullet proof..
