Old 08-02-2012, 04:23 PM   #1
ford E350 5.8 high idle problem
ok just like the subject says
93 e350 5.8 auto
the idle last couple months have been creeping up so i pulling the air box off to look into the throttle body ....
we found a few vacumm hoses off so i replaced the bad ones
still high idle
so we replace the idle air control valve no difference in the idle....
im thinking it might be TPS any thoughts?????
MrWicked is offline   Reply With Quote
Old 08-03-2012, 08:38 PM   #2
Re: ford E350 5.8 high idle problem
wow 31 looks but no comments....
Old 08-03-2012, 11:27 PM   #3
Ultrasport12's Avatar
I think the problem with no replies is no one has had that problem.
Personally I answer things I know about but I dont know anything about pre OBDII (1995 or older) Fords fuel injection.
A lot of the guys on here have diesels and V-10s or newer V-8 vans with OBDII and can use a scanner for problems like that.
Did you check the blink codes? It should have at least one.
It sounds like a vacuum leak at least on the cars I know about that would be the problem.
Oh I just found this maybe it would help.
http://www.f150online.com/forums/v8-eng ... -5-8l.html
Good luck..please post what fixes it even if know one replies.. then if nothing else we might be able to help the next time..
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 08-06-2012, 11:30 PM   #4
Check to make sure the throttle body isn't sticking open. This can be just from a dirty throttle body, but it could also be a rusty throttle cable.
Is it a MAF (mass airflow) or MAP (manifold absolute pressure) driven system? If it is MAP, a bad MAP sensor can cause high idle. The sensor basically upstream of everything else in the whole fuel/air management system. MAF setups are a little smarter.
If you rule out the MAP sensor, take some carb-cleaner and spray around the intake. An intake leak can cause erratic idle.
Old 08-07-2012, 04:57 PM   #5
thanks for the info ... i havent had a chance to check things but need to soon....
if and when i find the problem i will post what it was so it may can help others....
Old 08-07-2012, 08:39 PM   #6
BIGVANS's Avatar
I would also recommend checking for a vacuum hose or intake air leak.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 08-10-2012, 09:57 AM   #7
thanks for the input... i think we have a few things going on and next week i can try to start looking....
i noticed after the idle valve install when you start van up 1st thing and then step on gas pedal
it acts like ts stuck.... so i look and the throttle body and tried to move the butterfly's to see if it was staying open and didnt see any movement...
also after it runs for about a min you can hear the idle change like a valve opened and then thats when the idle gets higher....
next week ill have time to dig in and look at things....
Old 10-02-2012, 06:42 PM   #8
well next week turned into a few months.....
we are changeing out the TPS should have it back together later this week.... i will let you know what happens...
Old 10-02-2012, 06:59 PM   #9
BIGVANS's Avatar
Cool! I feel bad we can't help more from out here in cyberspace but you did work up some curiosity!
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 10-04-2012, 09:01 AM   #10
thank s for all the suggestions.... we got it back together and fired it off
it runs and after 30seconds the idle goes down instead of hogher like it was doing.....
so it was the TPS now we will buttom everthing up and take it on a test run at lunch time today....
My Van
bfolens
DADDOZR
REDOVAL
