Old 12-26-2014, 12:45 PM   #1
2011 Sprinter would not start and the 80 cent solution
We were leaving for a trip when our 2011 Sprinter 2500 would not start. It had started an hour earlier without a problem and now it would even try to start. After having it towed to Mercedes we found the problem to be an 80 cent fuse and were given the following notice provided by Mercedes. "2009, 2010, & 2011 Sprinter Vans. If a customer calls with the following complaint of 2009, 2010 & 2011 Sprinter: 1. The vehicle was running fine, the engine was powered off. 2. The Sprinter will not start and there is no cranking. Possible Solution: The starter relay fuse may be blown. The position of the 20A fuse is located in the fuse block on the left side of the dash in the driver footwell, position F23. If blown please replace with a 25A. This should resolve the issue." Hope this helps someone.
shirjoin is offline   Reply With Quote
Old 12-26-2014, 04:10 PM   #2
Re: 2011 Sprinter would not start and the 80 cent solution
Thanks for sharing. I'll be replacing with a 25 amp fuse in the am. DocD
docd is offline   Reply With Quote
