Re: Sewer hose storage tube length
Welcome to the forum!
Not sure and it probably depends on which SMB location and anyway you can specify what you want. The 20-foot slinky hose from Walmart is very high quality, it stretches to 20 feet (almost always enough) and stores in about 5 feet of 4-inch PVC pipe. Not sure this meets RVIA specifications (so SMB can't do it) but I rigged up mine to store the hose next to the exit fitting so I never have to disconnect it. Hooking up the fitting is always the worst part of dumping since a few drops come out when you take off the blank-off and again when you disconnect the hose.
David
