Old 03-18-2014, 12:17 PM   #1
stiggs's Avatar
Send a message via ICQ to stiggs Send a message via AIM to stiggs
water tank fittings loose
I was at the beach this weekend and used the sink, noticed a little later water dripping from under the van. The connector near the water pump had worked itself loose. I am guessing I need to go through the system and check all fittings, is it common for them to work loose?
2000 Ford RB30 PH 2WD -- Eagle Rock California
stiggs is offline   Reply With Quote
Old 03-18-2014, 01:32 PM   #2
Re: water tank fittings loose
It is not surprising. The pump, depending on how it's plumbed and operated, can generate a lot of vibration that works things loose. I haven't had any issues with PEX fittings, but some of the threaded fittings have loosened over time.
dparkwy is offline   Reply With Quote
