Old 05-25-2014, 07:11 PM   #1
Passenger Side Pwr Window Kill Switch?
I have a small dog that likes to jump up on the drivers side armrest. When he does this, the window lowers or the door locks go up and down. It's annoying and other than leaving him at home, does anyone of a solution to this issue that has worked for them? I sawed off half of a paint roller and taped it over for this recent trip, but it does not look good. HELP....
OneWagonHo is offline   Reply With Quote
Old 05-26-2014, 04:08 AM   #2
Re: Passenger Side Pwr Window Kill Switch?
There will be a single power feed wire for the switch block----interrupting it would be your kill switch.
The where to mount, how to wire etc greatly depends on your year and make of van.
Old 05-26-2014, 09:01 AM   #3
yvrr's Avatar
We had the same problem with our cat so I made this device using 1/2" PVC pipe:
It blocks both the window power switch and power door locks. I have another for the driver's side door when we need to leave him in the van (never when it is hot!) so that he won't accidentally unlock a door. The device doesn't bother my wife so she leaves it in all of the time but I remove the one for the driver's side and put it in only when needed.
Jack
'01 Ford EB50p Quigley 4WD
Old 05-27-2014, 05:34 AM   #4
Wow ^^^ that's very clever!
Even though its a passive device that needs slightly more effort putting it to use than a switch its a great way to accomplish this task.
Old 06-25-2014, 06:15 AM   #5
I have cats that love to travel, that device could be a lifesave, I love it
hippyman is offline   Reply With Quote
Old 06-25-2014, 06:54 AM   #6
viewtopic.php?f=14&t=7068
Old 06-25-2014, 09:41 AM   #7
Pschitt's Avatar
Much easier: just educate your dogs!
