Old 07-19-2014, 08:49 PM   #1
Updating and replacing Seats?
I have a 1998 E350 Clubwagon 12 passenger van with the old seats and no armrests. Do the seats from the newer Econoline vans bolt straight in or would they need to be modified?
Thedean2000 is offline   Reply With Quote
Old 07-22-2014, 04:41 AM   #2
Re: Updating and replacing Seats?
I think armrest seats first appeared in '03 or so? That being so anything from '97 forward should be a straight swap assuming factory bases are used.
My '03 came with armrests----they were the second thing I removed!
Old 07-22-2014, 06:52 AM   #3
Yes, all the same, easy mod. You can find armrests on certain trims all the way back in to the early 90's but they have always been in demand as an upgrade for base vans and most are gone by now or worn. All of the XLT's from around 2000 up have an inner armrest (right side of the driver seat and left side of the passenger seat). These are still MUCH better seats than the vinyl base seats. It's an easy 4 bolt swap. The only ones I'm NOT sure of are the newer Ford vans with the different grill (08-09 up?) but I'd be willing to be they're the same too. Keep in mind that there are LOTS of conversion vans out there with aftermarket seats. What I speak of are the OEM Ford seats. No telling what you are going to find in a conversion van.
Old 07-24-2014, 04:03 AM   #4
Not sure if this is helpful but here are dimensions of an OEM seat base, ca 2003:
This is the passenger side floor, OEM style:
As Scotty says OEM bases are key to compatibility.
HTH
