Old 07-02-2015, 03:20 PM   #1
Faucet Leak
There is a leak on our sink faucet where the handle/faucet attach to the "pull-out" hose. It looks like someone may have over-tightened the handle (female connection) to the hose . Does anyone know the make/model of the faucet on a 2007 SMB and if a replacement part is available? Let me know if a picture would help. Thanks and happy July 4th a bit early.
Old 07-03-2015, 09:45 AM   #2
yvrr's Avatar
Re: Faucet Leak
Email Peter Del Toro at SMB West (p.deltoro@sportsmobile.com) and he can tell you...
Jack
'01 Ford EB50p Quigley 4WD
Old 07-04-2015, 10:04 AM   #3
Re: Faucet Leak
Thanks, I'll update this post once I figure it out. I actually have to go up there sometime soon for a new 4D battery and cracked water pump fix.
Old 01-02-2018, 12:14 PM   #4
2007 sink / faucet
Faucet
This is a very late reply, but thought I'd put it up for anyone who needed it.
I have a 2007 SMB, the sink faucet is by Ambassador Marine. Model 134-0262-CW (OEM) or 135-0262-CW (aftermarket).
Mine was leaking (as in not turning off completely). After emailing pictures to Ambassador, they sent me out new cartridges (the on off guts) that install under the knobs. Note, you will need new red and blue plastic "dots" too as they must be destroyed to remove them to get at the screw to remove the handle.
Ambassador's info in included in the attached infosheet.
Hope that helps anyone who needs it.
Sam C is offline   Reply With Quote
