Old 07-15-2015, 07:57 AM   #1
General questions
Hi all, my wife and I just did a shop visit in Huntington, In and after talking things over later in the day came up with a few questions I was hoping you might be able to help out with.
1. I love the 7 cubic foot fridge but am concerned the energy use might be too great, would we be better off with a smaller one?
2. How long will an electric heater run on battery power through the inverter?
3. Can a toaster or a crock pot be run via battery through the inverter?
4. If we were to go with diesel appliances (much more expensive I know) will there be a residual smell of diesel fuel that hits your nose every time you enter?
Thanks for your help!
TallGuy is offline   Reply With Quote
Old 07-15-2015, 08:32 AM   #2
yvrr's Avatar
Re: General questions
Note that the 7 CF refrigerator can only be installed in Sprinters. According to the SMB website, the amperage draw is about the same as the smaller one which is a little surprising/suspicious. We have a 4.6 CF Isotherm in our van and it works out fine for us. If we are gone for a week, we might eat lunch along the way several days and go out to dinner once or twice. We will BBQ something for dinner about half the evenings. We have been out for as long as 3 weeks in Mexico and only purchasd a few items along the way.
We have a propane heater in our van which has a very low-draw fan. With the top up and sleeping in the penthouse, the heater doesn't come on at night even when snow camping. A standard electric heater can only be used with a generator or shore power...electric heat is not very efficient.
Likewise, a crock pot that is left on during the day will drag down the house battery. You are probably fine with a toaster but Iwould want to keep an eye on the house battery voltage.
Jack
'01 Ford EB50p Quigley 4WD
Old 07-15-2015, 08:42 AM   #3
From an energy point of view, smaller is better, since heat loss "into" the fridge would be less with less surface area. From a convenience standpoint, that's a question only you can answer.
I'm not familiar with the fridges that SMB is spec'ing, but the 3 popular sizes of Truckfridges that folks here commonly install all have the same size compressors/evap/condensers. None of those are near 7 ft3. The larger units will just take more time to cool down and use a bit more power due to heat loss.
Not very long.......only really viable on shore power. Let's take a 1200W heater for easy math....that's less than a typical blow dryer. Ignoring the inefficiencies of an inverter, 1200W at 12V draws 100 amps. So if you have a 100ah battery you will be 50% discharged in 30 minutes. As a general rule-of thumb, you only want to discharge lead acid batteries to about 50% before recharging.
So, best case 30 minutes.......let's assume your heater is 1200W at 120V (using the inverter) and let's also assume that your inverter is 90% efficient, then 30 minutes x .9=27 minutes.
Sure, just not very long.....these both have very similar power requirements to the heater example above, so they are only really viable on shore power. Same with an electric coffee maker. Toaster maybe, since making one batch of toast is maybe 3-4 minutes.
If you can handle lots of battery capacity and solar, you could get more time, but it will never be enough to run a crock pot or an electric heater for too long.
Old 07-15-2015, 10:29 AM   #4
Viva's Avatar
Presuming both of the refrigerators are 12 volt compressor type fridges (not propane powered) I agree that a 7 cu. ft. refrigerator speccing the same draw as a much smaller one seems suspicious. If it WERE true, (and presuming the 7 cu. fit one is not the size of a barn due to miles of insulation), then the 7 cu. ft. one would have to have a much higher percentage duty cycle, meaning it would use more energy in the end. Here are a couple of examples of what I mean:
Example 1, from my Vitrifrigo catalog:
Vitrifrigo, a common brand of good-quality 12 volt compressor refrigerators, does have much higher draw spec on the 8 cu. ft than the 4 cu. ft. (they don't have a 7). This tells me they are using an appropriately larger compressor (probably a Danfoss 50 as opposed to a Danfoss 35). I would expect these refrigerators to have similar duty cycles (maybe a bit more for the larger one). By duty cycle I mean what percentage of a 24-hour period it's actually running, vs. coasting.
4.2 cu. foot = 3.8 amps. At 50% duty cycle this would be 45.6 amps used in a 24-hour period.
8.0 cu. foot = 5.38 amps. At 60% duty cycle this would be 77.5 amps in a 24-hour period.
5.3 cu. foot = 5.38 amps. The 5.38 figure tells me it's the same compressor as the 8, and so it should have a smaller duty cycle, say 40%. That would be 54 amps per 24-hour period.
Example 2
A company that theoretically uses the same compressor for a 4 cu. ft. fridge and a 7 cu ft fridge (hence same amp draw listed for both).
Theoretical 4 uses 3.8 amps. At 50% duty cycle this is 45.6 amps per 24-hour period.
Theoretical 7 uses 3.8 amps. At 75% duty cycle this is 78 amp hours per day.
So as you can see there sort of isn't a "free lunch" on refrigerator draw. If a larger refrigerator is specifying a lower draw, that likely just means that they are using a smaller compressor, BUT it will have to run more to remove heat from a larger "box." The only way around that would be to have it be disproportionately large on the outside (more insulation), but then it would likely not fit reasonably in a van. There is also the chance of more wear on the compressor if a smaller on is used in a larger box (they have figures for compressor/box sizing -- or at least Danfoss does -- so this can be determined).
I think most refrigerator makers do not specify duty cycle because who knows what your ambient temperature will be. However I WISH they would specify that for a set temp, say 77º. Having that figure along with the hourly amp draw of the compressor would allow one to plan for a power system, plus compare insulation value of various refrigerators.
PS: In general, when planning for your power system, think about three things:
1) What sort of draw and for how long in a 24-hour period on each appliance.
2) How much power storage capability do you have (batteries) (don't plan to draw them down 100% or they will die very prematurely).
3) How are you planning to "put back" power you have used, and how often.
With these three pieces you can get a basic perspective on your use. Two opposite examples:
A) Parsimonious boondocker.
1) Uses 85 amp hours in a 24-hour period
(refrigerator = 50; computer, etc. = 15; lights and water pump = 10; misc. = 10)
2) Has a 300 amp hour battery bank, so the daily draw uses around 28% of that. Hence 2-3 days without charging (or with meager charging due to clouds etc.) are not an issue.
3) Has 200-300 watts of solar to "put back" the power used. Can be supplemented by occasional driving (alternator will reliably charge batteries back up to 85%).
B) Luxuriies of Home folks
1) Uses 300 amp hours in a 24-hour period (luxuries of home )
2) Has a 300 amp hour battery bank, so the daily draw would be 100% of that (not acceptable, but see #3)
3) But is plugged in every night (110 charger), and/or runs generator to charge (110 charger).
Both of the above scenarios "work," but the Parsimonious Camper has to watch usage carefully (or change system). The Luxuries of Home folks have to plug in every night and/or run generator. So the main thing is to match the system to the style (and of course there is middle ground).
Old 07-15-2015, 09:18 PM   #5
I'd ask them to do an amp check on the fridge. Norcold made some changes over the last year and I'm guessing that is what they're installing. Even Norcold's web site was incorrect back in November.
Yep an electric device like microwave, toaster, heater or crock pot will pull a lot as mentioned. That is why people with such items often need a generator or shore power. A large battery bank can run a microwave for a few minutes but it's usually best to run the engine while it's going.
They do make propane powered crock pots.
Old 07-16-2015, 10:00 AM   #6
1. I have no idea of the power draw, but we can fit a LOT of food in our 4+/- cubic ft. Truckfridge. We take a small cooler for tall drink bottles, beer and soft drinks, and that's where we keep ice too. It works out great. Keep in mind that fridge will take up a lot of your space as well as possibly eating a lot of power.
2. I suspect a very short time. Home electrics (toasters, hair dryers, heaters, crock pots) use a whole lot more power than you think.
3. I think you could do this with the motor running. That's what we do with our microwave. We just crank up the van, and usually for the 5 minute cycle of using a coffee pot too, when we use it. It's not necessary with our two big AGM batteries but it keeps from zapping them so they can carry on supporting our lights and other small electronics. We have often thought of traveling with our Crock Pot and just letting it sit in the sink or somewhere and cook food while we drive all day, using the inverter supported by the running van. This isn't perfect, but crock pot food is perfect, so it might be a good trade off on a long driving day.
4. I don't think they put out any smell at all. I've been in a few vans with diesel appliances and never detected a smell. I would PM Pschitt. He has all diesel stuff I think.
It seems to me you are looking to avoid propane, but it is cheap after the original tank install, and worry free. Also, your biggest choice of appliances will be propane. The only thing propane I would avoid is a fridge due to the better and cheaper electric choices these days.
Old 07-16-2015, 10:08 AM   #7
mikracer's Avatar
^^ That sounds like a pretty good idea to me! If you stopped along the way, you could just turn it off and let the residual heat continue to do its thing. Only downside would be storing the crockpot afterwards.
Old 07-16-2015, 11:19 AM   #8
Viva's Avatar
To pile onto a tangent, you might consider a thermal cooker to do the job of an electric crockpot, if you haven't already. It's basically like a non-electric crockpot, stainless/vacuum-insulated. You heat it up at first on any stove (with the stew or whatever inside it), then then set it aside (such as in the sink) and it does the crockpot thing on its own. Then holds things warm. Here is one example, the Thermos Shuttle Chef (not particularly endorsing this one, but just wanted to show a photo and grabbed it in a search).
Old 07-16-2015, 09:29 PM   #9
Have had one for years (still use it) and it fits some situations but not quite like a crock pot.
I can cook more things via a propane stove than that mind you there is fuel to consider.
It all depends how you need to cook.
Old 07-17-2015, 02:30 AM   #10
Viva's Avatar
Fair enough, DaveB. And, I haven't even used a thermal cooker - just thought they looked interesting. I don't cook in a crockpot either though (lot of use I am!).
Glad you commented.
PolarVan
PolarVan
Moby
maptester
