Old 10-28-2015, 06:46 PM   #1
Magnum Converter/Inverter
Hello,
I have a Magnum Converter/Inverter in my Yellow SMB but it is in the U.S.
What model number Magnum converter/Inverter do you have in yours please?
This will help me determine which model CE/European 220/230volt I need.
I think the one I need to convert to 230volt CE is the Magnum 2712E or Magnum MS-E 2712?
The remote digital controller unit is the same for 110/220volt.
Looking forward to your input.
Cheers Doug,
Old 10-28-2015, 07:13 PM   #2
Scalf77's Avatar
Re: Magnum Converter/Inverter
I believe you are correct the model you need is Model: MS-2712E.
I believe the standard unit SMB uses in US is MS2000.
Greg
Old 10-28-2015, 07:34 PM   #3
tlg
tlg's Avatar
Sheriff, our 2014 build included a Magnum 2000W MS Series Pure Sine Wave Inverter/Charger. Nice rig by the way!
2014 Ford RB-50
tlg is offline   Reply With Quote
