Old 08-18-2014, 07:29 AM   #1
Tracker926's Avatar
Hella light install
I have a set of Hella 500 lights I want to install on the Aluminess front bumper attached to my 2012 E150. I am confused about how to wire them in and how to install the switch. Searched the forum but couldn't find any specific instructions for a novice like me. Has anyone done this, and can you condense it down to some easy to understand instructions?
Tracker926 is offline   Reply With Quote
Old 08-18-2014, 08:16 AM   #2
Tapatio's Avatar
Re: Hella light install
I chose not to install a switch. I wired the lights to trigger off of the high beam. What part of the instructions are tripping you up?
http://www.myhellalights.com/index.p...ile/-/view/654
Callsign KK6GIY
Old 08-18-2014, 10:25 AM   #3
Tracker926's Avatar
86 the yellow wire. Goes from the relay to the switch, and from the switch to ? To eliminate the switch and trigger off the high beam would I just tie into the wires for high beam. I am a true novice and am grateful for advice/help.
Old 08-18-2014, 01:25 PM   #4
Tapatio's Avatar
Yes, if you don't want a switch in the van connect relay post 86 to one of the high beam positive wires. Each headlight has 3 wires, low +, high + and ground. I used a multi meter to find the high +.
Callsign KK6GIY
Old 08-18-2014, 01:57 PM   #5
Here is my install of PIAA lights on a stock bumper. However, I'm guessing the basics should be pretty similar.
http://www.sportsmobileforum.com/vie...hp?f=13&t=1581
Babe
Babe
Moby
maptester
