Old 02-04-2015, 04:35 PM   #1
Need a PCM
Monday my PCM took a dump. Will not communicate with the scanner and according to rebuiltautoelectronics the board that fried is no longer available.
I am looking for a F7UF-12A650-AFC
DPC-315
PPB2
van is a 97 E350 7.3
Old 02-04-2015, 04:49 PM   #2
E350's Avatar
Re: Need a PCM
According to tuning guru Cleatus12r over at ford-trucks.com there are a lot of van PCMs on ebay for cheap because they will not work in the F series. If I can I will find the thread for you.
You have your PCM's number so you should be able to locate an identical PCM.
I bought a reman PCM from Auto Computer Exchange on ebay for my wife's 2000 Dodge Dakota 4x4 for $169 and after figuring out that my wife's vehicle had oem theft deterent programming in the PCM, they sent me a great PCM which recently failed just before warranty expiration due to physical damage caused to the back cover adhesive arising from the extreme heat in Sacramento this last Summer. I can't yet comment on their warranty replacement PCM.
Please post what you find.
Old 02-04-2015, 07:28 PM   #3
Re: Need a PCM
I must be doing something wrong on ebay.....I only found 3 for sale for the vans
Old 02-04-2015, 08:42 PM   #4
E350's Avatar
Re: Need a PCM
You put the part number in the search field so it gave you only the three which have that part number in the title. If you put in 97 E350 pcm you will come up with 20, but you will have to sort through them to see if they are compatible.
Might want to follow these leads:
http://www.siaelec.com/index.aspx
Also call and ask DP for their advice:
http://www.dp-tuner.com/ford-powerstrok ... ing-1.html
Also check these guys that I bought a Dodge PCM from:
https://www.autocomputerexchange.com/
http://carcomputerexchange.com/?ibp-adg ... ource=bing
http://www.ebay.com/itm/F8UF-12A650-ALB ... 1677137519
Also the attached .pdf lists the PCM that the autodismantler carpart.com has. Check it out.
Old 02-05-2015, 04:44 AM   #5
Re: Need a PCM
Is it more important for the hardware # to match [DPC-315]
or
for the hardware # and part # to both match?
Old 02-05-2015, 05:34 AM   #6
Re: Need a PCM
I will be on the phone today.
Thank you for the information!!!!!
Old 02-05-2015, 05:43 AM   #7
E350's Avatar
Re: Need a PCM
or
I don't know the answer to that. So make sure you ask DP. I wish you could pm Cleatus12r, but he is so popular at ford-trucks.com that he turned off his pm feature. I looked for the thread where he discussed van pcm's but I couldn't find it. I will look again. Good luck! Please post what you learn so we all can learn.
Old 02-05-2015, 08:25 AM   #8
E350's Avatar
Re: Need a PCM
Post a new thread entitled "Where can I find a PCM for a 97 E350 7.3L? in this forum:
http://www.ford-trucks.com/forums/forum170/
Old 02-05-2015, 01:18 PM   #9
Re: Need a PCM
As long s the hardware is the same they will interchange ie ll DPC-315 will work on my van
POWER STROKE PCM CALIBRATION INFORMATION
YEAR CODE CALIB. MODL TYPE ECM PART # APP. MODULE APP. TEMPLATE
2000 ADR0 0FC29E0511 DPC-428 YC3F-BGA 7.3L F-650/750 DIESEL - AUTOMATIC 50S VPAB3E4
2000 ADR1 0FC29E0512 DPC-428 YC3F-BGB 7.3L F-650/750 DIESEL - AUTOMATIC 50S VPAB3E5
2002 AEB0 2F729Q0A00 DPC-461 2C3F-BA 7.3L F-250/350 DIESEL - MANUAL 49S TOAA2Q3
2002 AEB1 2F729Q0A05 DPC-461 2C3F-BB 7.3L F-250/350 DIESEL - MANUAL 49S TOAA3Q2
2002 AEB2 2F729Q0A06 DPC-461 2C3F-BC 7.3L F-250/350 DIESEL - MANUAL 49S TOAA4Z2
2002 AEB3 2F729Q0A10 DPC-461 2C3F-BD 7.3L F-250/350 DIESEL - MANUAL 49S TOAA5Z5
2002 AEB4 2F729Q0A10 DPC-461 2C3F-BE 7.3L F-250/350 DIESEL - MANUAL 49S
1996 AFL1 N/A DPC-203 F6TF-AUB FMEF20L4
1999 AGD0 9DTA-ASA DPC-422 XC3F-RB 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VJAE0S2
1999 AGD1 9DTA-ASA DPC-422 XC3F-RC 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VJAE1S4
1999 AGD2 9DTA-ASB DPC-422 XC3F-RD 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VJAE3S3
1999 AGD3 9DTA-ASC DPC-422 XC3F-ERD 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VJAE3S5
1996 ALF0 6-89A-R00 DPC-203 F6TF-AUA 7.3L F-250/350 DIESEL - MANUAL 49S/ALT/CAN FMEF20J4
1996 ALF2 6-89A-R01 DPC-203 F6TF-AUC 7.3L F-250/350 DIESEL - MANUAL 49S/ALT/CAN FMEF20M2
1996 ALF4 6-89A-R02 DPC-203 F6TF-AUE 7.3L F-250/350 DIESEL - MANUAL 49S/ALT/CAN FM20M06
1995 ALF5 5-89K-RXX DPC-203 F6TF-AUF 7.3L F-250/350 DIESEL - MANUAL 49S/ALT/CAN FM20N2
1996 ALF6 6-89A-R11 DPC-203 F6TF-AUG 7.3L F-250/350 DIESEL - MANUAL 49S/ALT/CAN FM20P402
2001 APX0 1F29Q0A00 DPC-411 1C3F-YA 7.3L P131 F-250/350 VSAA2QB
2001 APX1 1F729Q0A05 DPC-411 1C3F-YB 7.3L P131 F-250/350 VSAA4Q9
1999 ATA0 9DTM-BGA DPC-431 XC3F-CB 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VKAE0G5
1999 ATA1 9DTM-BGA DPC-431 XC3F-CC 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VKAE1G2
1999 ATA2 9DTM-BGB DPC-431 XC3F-CD 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VKAE3G2
2000 ATA3 9DTM-BGC DPC-431 XC3F-CF 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VOAA7G5
2000 ATA4 9DTA-BGC DPC-431 XC3F-CG 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VOAA8G4
1996 AUG0 6-89N-R00 DPC-203 F6TF-ATA 7.3L F-SERIES DIESEL CAL FMEF20J2
1996 AUG1 6-89N DPC-203 F6TF-ATB 7.3L F-SERIES DIESEL CAL FMEF20L2
1996 AUG2 6-89N-R01 DPC-203 F6TF-ATC 7.3L F-SERIES DIESEL CAL FMEF20M4
1996 AUG4 6-89N-R02 DPC-203 F6TF-ATE 7.3L F-250/350 DIESEL CAL FM20M08
1996 AUG5 6-89N DPC-203 F6TF-ATF 7.3L F-250/350 DIESEL CAL FM20N4
1996 AUG6 6-89N DPC-203 F6TF-ATG 7.3L F-250/350 DIESEL CAL FM20R02
1996 AUG7 6-89N-R12 DPC-203 F6TF-ATH 7.3L F-250/350 DIESEL CAL FM20R402
2000 AVB0 0F719N0B11 DPC-452 XU7F-CA 7.3L P131 VNAB6N2
1999 AWA0 9DTM-AGA DPC-401 F81F-AB 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VIAD8G2
1999 AWA1 9DTM-AGB DPC-401 F81F-AC 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VIAE1G8
1999 AWA2 9DTM-AGC DPC-401 F81F-AD 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VIAE7G3
1999 AWA3 9DTM-AGD DPC-401 F81F-AE 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VIAE9GD
1999 AWA4 9DTM-AGD DPC-401 F81F-AF 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VIAF3G4
1999 AWA5 9DTM-AGD DPC-401 F81F-AG 7.3L F-250/350 DIESEL - MANUAL SERV FIX 49S COLD WTR VIAF3G7
2000 AXD0 0L119Y0B10 DPC-452 YC3F-AVA 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS/GPCM VNAB1Y2
2000 AXD1 0L119Y0B11 DPC-452 YC3F-AVB 7.3L EXCURSION DIESEL - AUTOMATIC CACKLE FIX 50S EPATS/GPCM VNAB5Y2
1999 BAW0 9DTM-AQB DPC-421 XU2F-VA 7.3L F-250/350 DIESEL - MANUAL SERVICE 50S COLD WTR VKAE4Q5
1999 BAW1 9DTM-AQB DPC-421 XU2F-VB 7.3L F-250/350 DIESEL - MANUAL 50S COLD WTR VKAE4Q7
1997 BCT0 8-90K-R10 DPC-315 F8UF-ANA 7.3L E-350 DIESEL - AUTOMATIC 50S/CANADA VEAB1_0C
1999 BDT0 9DTM-ABA DPC-401 F81F-JA 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VIAD8B4
1999 BDT1 9DTM-ABB DPC-401 F81F-JB 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VIAE1B4
1999 BDT2 9DTM-ABC DPC-401 F81F-JC 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VIAE7B4
1999 BDT3 9DTM-ABD DPC-401 F81F-JD 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VIAE9B2
1999 BDT4 9DTM-ABD DPC-401 F81F-JE 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VIAF3B4
1999 BDT5 9DTM-ABD DPC-401 F81F-JF 7.3L F-250/350 DIESEL - MANUAL SERV FIX 49S WARM WTR VIAF3B7
1994 BEG5 5-89 -R00 DPC-203 F5TF-FF 7.3L F-SERIES DIESEL - MANUAL TURBO DIESEL FNDM009G02
1994 BEG5 5-89 -R00 DPC-203 F5TF-FF 7.3L F-SERIES DIESEL - MANUAL TURBO DIESEL FDMEF9G002
1994 BEG6 5-89 -R00 DPC-203 F5TF-FG 7.3L F-SERIES DIESEL - MANUAL TURBO DIESEL FNDM009G03
1994 BEG6 5-89 -R00 DPC-203 F5TF-FG 7.3L F-SERIES DIESEL - MANUAL TURBO DIESEL FDMEF9G003
1994 BEG8 5-89K-R00 DPC-203 F5TF-FJ 7.3L F-SERIES DIESEL - MANUAL TURBO DIESEL FDMEF9G4
1999 BIS0 9DTM-ANA DPC-421 XC3F-JB 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VKAE0N4
1999 BIS1 9DTM-ANA DPC-421 XC3F-JC 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VKAE1N2
1999 BIS2 9DTM-ANB DPC-421 XC3F-JD 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VKAE3N3
2001 BKA0 1F719T0A00 DPC-422 1C3F-ADA 7.3L F-450/550 DIESEL - AUTOMATIC 50S VRAA4T4
2001 BKA1 1F719T0A05 DPC-422 1C3F-ADB 7.3L F-450/550 DIESEL - AUTOMATIC 50S VRAA6T3
2001 BKA2 1F719T0A10 DPC-422 1C3F-ADC 7.3L F-450/550 DIESEL - AUTOMATIC 50S VRAA7T5
2001 BKA3 1F719T0A11 DPC-422 1C3F-ADD 7.3L F-450/550 DIESEL - AUTOMATIC 50S VRAA7T6
2002 BXE2 2F719T0506 7.3L F-450/550 DIESEL - AUTOMATIC 50S
2002 BXE3 7.3L F-450/550 DIESEL - AUTOMATIC 50S
2002 BXE5 7.3L F-450/550 DIESEL - AUTOMATIC 50S
1999 CHK0 9DTA-BG DPC-435 XC2F-ANB 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VLAE0G4
1999 CHK2 9DTA-BGB DPC-435 XC2F-ANC 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VLAE3G2
2000 CHK3 9DTA-BGC DPC-435 XC2F-AND 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VMAA8G9
2000 CHK4 9DTA-BGD DPC-435 XC2F-ANE 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VMAA8GB
2000 CHK5 9DTA-BGD DPC-435 XC2F-ANF 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VMAA8GD
1999 CLB0 9DTM-AHA DPC-401 F81F-KA 7.3L F-450/550 DIESEL - MANUAL 50S COLD WTR VIAD8HA
1999 CLB1 9DTM-AHB DPC-401 F81F-KB 7.3L F-450/550 DIESEL - MANUAL 50S COLD WTR VIAE1H5
1999 CLB2 9DTM-AHC DPC-401 F81F-KC 7.3L F-450/550 DIESEL - MANUAL 50S COLD WTR VIAE7H3
1999 CLB3 9DTM-AHD DPC-401 F81F-KD 7.3L F-450/550 DIESEL - MANUAL 50S COLD WTR VIAE9H2
1999 CLB4 9DTM-AHD DPC-401 F81F-KE 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VIAF3H4
1999 CLB5 9DTM-AHD DPC-401 F81F-KF 7.3L F-450/550/650 DIESEL - MANUAL SERV FIX 50S COLD WTR VIAF3H7
1999 CNH0 9DTA-AVA DPC-422 XC3F-PB 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VJAE0V4
1999 CNH1 9DTA-AVA DPC-422 XC3F-PC 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VJAE1V5
1999 CNH2 9DTA-AVB DPC-422 XC3F-PD 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VJAE3V3
1999 CNH3 9DTA-AVC DPC-422 XC3F-EPD 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VJAE3V5
2000 CNH4 9DTA-AVD DPC-422 XC3F-PF 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VNAA8V7
2000 CNH5 0F729T0A00 DPC-422 XC3F-PG 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VNAA9T4
1999 DAC0 9DTM-APA DPC-421 XC3F-AB 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VKAE0P4
1999 DAC1 9DTM-APA DPC-421 XC3F-AC 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VKAE1P2
1999 DAC2 9DTM-APB DPC-421 XC3F-AD 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VKAE394
2000 DAC3 9DTM-APC DPC-421 XC3F-AF 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR VOAA7P6
DAC4 9DTM-AP DPC-421 XC3F-AG 7.3L F-250/350 DIESEL - MANUAL 49S COLD WTR
1999 DYK0 9DTM-ACA DPC-401 F81F-LA 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VIAD8CC
1999 DYK1 9DTM-ACB DPC-401 F81F-LB 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VIAE1C5
1999 DYK2 9DTM-ACC DPC-401 F81F-LC 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VIAE7C4
1999 DYK3 9DTM-ACD DPC-401 F81F-LD 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VIAE9C2
1999 DYK4 9DTM-ACD DPC-401 F81F-LE 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VIAF3C4
1999 DYK5 9DTM-ACD DPC-401 F81F-LF 7.3L F-450-550/650 DIESEL - MANUAL SERV FIX 50S COLD WTR VIAF3C7
2001 EBM0 1L119Y0B00 DPC-452 1C3F-XA 7.3L EXCURSION DIESEL - AUTOMATIC 50S VRAA473
2001 EBM1 1L119Y0B05 DPC-452 1C3F-XB 7.3L EXCURSION DIESEL - AUTOMATIC 50S VRAA6Y3
2001 EBM2 1L119Y0B10 DPC-452 1C3F-XC 7.3L EXCURSION DIESEL - AUTOMATIC 50S VRAA7Y5
2001 EBM3 1L119Y0B11 DPC-452 1C3F-XD 7.3L EXCURSION DIESEL - AUTOMATIC 50S VRAA7Y6
EMB1 1-L11-9Y0-B05 1C3F-XB 7.3L EXCURSION DIESEL - AUTOMATIC CAL
EMB3 1-L11-9Y0-B11 1C3F-XD 7.3L EXCURSION DIESEL - AUTOMATIC CAL
1999 ETR0 9DTM-BAA DPC-411 F81F-MA 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VIAD8A8
1999 ETR1 9DTM-BAB DPC-411 F81F-MB 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VIAE1A4
1999 ETR2 9DTM-BAC DPC-411 F81F-MC 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VIAE7A4
1999 ETR3 9DTM-BAD DPC-411 F81F-MD 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VIAE9A2
1999 ETR4 9DTM-BAD DPC-411 F81F-ME 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VIAF3A3
1999 ETR5 9DTM-BAD DPC-411 F81F-MF 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VIAF3A6
1997 FCZ0 7-90D-R00 DPC-315 F7UF-APA 7.3L ECONOLINE RYDER FA30T508
1997 FCZ2 7-90D-R10 DPC-315 F7UF-APC 7.3L ECONOLINE RYDER FA30T838
2000 FHM0 0E419Q0B10 DPC-455 XC2F-AZA 7.3L E-350/450 DIESEL - AUTOMATIC CAL R/C VMAB1Q3
2000 FHM1 0E419Q0B11 DPC-455 XC2F-AZB 7.3L E-350/450 DIESEL - AUTOMATIC CAL R/C VMAB2Q3
2000 FHM2 0E419Q0B12 DPC-455 XC2F-AZC 7.3L E-350/450 DIESEL - AUTOMATIC CACKLE FIX CAL R/C VMAB6Q2
1999 FHP0 9DTA-BKA DPC-432 XC3F-DB 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VJAE0K6
1999 FHP1 9DTA-BKA DPC-432 XC3F-DC 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VJAE1K2
1999 FHP2 9DTA-BKB DPC-432 XC3F-DD 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VJAE3K3
2000 FHP3 9DTA-BKC DPC-432 XC3F-DF 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VNAA8K8
2000 FHP4 9DTA-BKC DPC-432 XC3F-DG 7.3L F-250/350 DIESEL - AUTOMATIC CACKLE/SERVICE CAL COLD WTR VNAA9K4
1999 FIF0 9DTA-ARA DPC-422 XC3F-NB 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VJAE0R2
1999 FIF1 9DTA-ARA DPC-422 XC3F-NC 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VJAE1R4
1999 FIF2 9DTA-ARB DPC-422 XC3F-ND 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VJAE3R2
1999 FIF3 9DTA-ARC DPC-422 XC3F-END 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VJAE3R4
1999 FUT0 9DTA-ACA DPC-402 F81F-NA 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAD8C4
1999 FUT1 9DTA-ACB DPC-402 F81F-NB 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAE1CG
1999 FUT2 9DTA-ACC DPC-402 F81F-NC 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAE7C6
1999 FUT3 9DTA-ACD DPC-402 F81F-ND 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAE7C8
1999 FUT4 9DTA-ACE DPC-402 F81F-NE 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAE9C2
1999 FUT5 9DTA-ACF DPC-402 F81F-NF 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAE9C6
1999 FUT6 9DTA-ACF DPC-402 F81F-NG 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAF4C4
1999 FUT7 9DTA-ACF DPC-402 F81F-NH 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAF5C3
1999 FUT8 9DTA-ACF DPC-402 F81F-NJ 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VHAF7C2
2002 GDU0 2F729R0A00 DPC-461 2C3F-CA 7.3L F-450/550 DIESEL - MANUAL 50S TOAA2R3
2002 GDU1 2F729R0A05 DPC-461 2C3F-CB 7.3L F-450/550 DIESEL - MANUAL 50S TOAA3R2
2002 GDU2 2F729R0506 DPC-461 2C3F-CC 7.3L F-450/550 DIESEL - MANUAL 50S TOAA4R2
2002 GDU3 2F729R0510 DPC-461 2C3F-CD 7.3L F-450/550 DIESEL - MANUAL 50S TOAA5R6
2002 GDU4 2F729R0510 DPC-461 2C3F-DE 7.3L F-450/550 DIESEL - MANUAL 50S TOAA?R?
2000 GEG0 0FC19F0511 DPC-428 YC3F-BFA 7.3L F-650/750 DIESEL - AUTOMATIC VPAB3F3
2000 GEG1 0FC19F0512 DPC-428 YC3F-BFB 7.3L F-650/750 DIESEL - AUTOMATIC VPAB3F4
1997 GLB0 8-90N-R10 DPC-315 F8UF-AJA 7.3L E-350 DIESEL - AUTOMATIC CAL VEAB1_08
1998 GLB1 8-90N-R11 DPC-315 F8UF-AJB 7.3L E-350 DIESEL - AUTOMATIC CAL VEAB206
1997 GLB2 8-90N-R12 DPC-315 F8UF-AJC 7.3L E-350 DIESEL - AUTOMATIC CAL VEAB20C
1990 GLF0 9DTA-ALA DPC-402 F81F-PA 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VHAD8L6
1999 GLF1 9DTA-ALB DPC-402 F81F-PB 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VHAE1LA
1999 GLF2 9DTA-ALC DPC-402 F81F-PC 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VHAE7L5
1999 GLF3 9DTA-ALD DPC-402 F81F-PD 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VHAE7L7
1999 GLF4 9DTA-ALE DPC-402 F81F-PE 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VHAE9L2
1999 GLF5 9DTA-ALF DPC-402 F81F-PF 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLS WTR VHAE9L7
1999 GLF6 9DTA-ALF DPC-402 F81F-PG 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VHAF4L5
1999 GLF7 9DTA-ALF DPC-402 F81F-PH 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VHAF5L3
1999 GLF8 9DTA-ALF DPC-402 F81F-PJ 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VHAF7L2
1999 GLI0 9DTM-BFB DPC-431 XU2F-YA 7.3L F-250/350 DIESEL - MANUAL SERVICE CAL WARM WTR VKAE4F6
1999 GLI1 9DTM-BFB DPC-431 XU2F-YB 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VKAE4F8
1994 GOB0 5-89 -R00 DPC-203 F5FF-FF 7.3L TURBO/DIESEL AFTERMKT/T.DIESEL FMEF9H01
2000 HAM0 0F719P0B12 DPC-422 YU7F-CA 7.3L P131 VNAB6P2
2000 HAM1 0F719P0B12 DPC-422 YU7F-CB 7.3L P131 VNAB6P3
2001 HJH0 1E419N0B00 DPC-455 1C2F-AHA 7.3L E-350/450 DIESEL - AUTOMATIC CAL VQAA4NB
2001 HJH1 1E419N0B05 DPC-455 1C2F-AHB 7.3L E-350/450 DIESEL - AUTOMATIC CAL VQAA6N2
2001 HJH2 1E419N0B10 DPC-455 1C2F-AHC 7.3L E-350/450 DIESEL - AUTOMATIC CAL VQAA7N3
2001 HJH3 1E419NOB11 DPC-455 1C2F-AHD 7.3L E-350/450 DIESEL - AUTOMATIC CAL VQAA9N3
2000 HMR0 0F729M0B10 DPC-451 XC3F-DCA 7.3L F-250/350 DIESEL - MANUAL CAL R/C VOAV1M3
2000 HMR1 0F729M0B11 DPC-451 XC3F-DCB 7.3L F-250/350 DIESEL - MANUAL CACKLE FIX CAL R/C VOAB5M2
1999 HPA0 9DTA-ADA DPC-402 F81F-RA 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAD8D8
1999 HPA1 9DTA-ADB DPC-402 F81F-RB 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAE1D8
1999 HPA2 9DTA-ADC DPC-402 F81F-RC 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAE7D6
1999 HPA3 9DTA-ADD DPC-402 F81F-RD 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAE7D8
1999 HPA4 9DTA-ADE DPC-402 F81F-RE 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAE9D2
1998 HPA5 9DTA-ADF DPC-402 F81F-RF 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAE9D6
1999 HPA6 9DTA-ADF DPC-402 F81F-RG 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAF4D4
1999 HPA7 9DTA-ADF DPC-402 F81F-RH 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAF5D3
1999 HPA8 9DTA-ADF DPC-402 F81F-RJ 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VHAF7D2
2001 HPI0 1E419M0A00 DPC-425 1C2F-AFA 7.3L E-350 ECONOLINE DIESEL - AUTOMATIC CAL VQAA4ME
2001 HPI1 1E419M0A05 DPC-425 1C2F-AFB 7.3L E-350 ECONOLINE DIESEL - AUTOMATIC CAL VQAA6M3
2001 HP12 1E419M0A10 DPC-425 1C2F-AFC 7.3L E-350 ECONOLINE DIESEL - AUTOMATIC CAL VQAA7M4
2001 HP13 1E419M0A11 DPC-425 1C2F-AFD 7.3L E-350 ECONOLINE DIESEL - AUTOMATIC CAL VQAA9M3
1997 HPQ1 7-90Q-R00 DPC-315 F7UF-ANB 7.3L E-350 DIESEL - AUTOMATIC FA30T50I
1997 HPQ2 7-90Q-R10 DPC-315 F7UF-ANC 7.3L E-350 DIESEL - AUTOMATIC FA30181A
1999 HQN0 9DTA-BKB DPC-432 XU2F-TA 7.3L F-250/350 DIESEL - AUTOMATIC SERVICE CAL COLD WTR VJAE5K4
1999 HQN1 9DTA-BKB DPC-432 XU2F-TB 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VJAE6K4
1999 HQN2 9DTA-BKB DPC-432 XU2F-TC 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VJAE7K2
1999 HQN3 9DTA-BKB DPC-432 XU2F-TD 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VJAE7K3
2000 HRU3 0FC29E0500 DPC-427 YC3F-APD 7.3L F-560 - ALLISON AUTOMATIC VPAB0E3
2001 IQW0 1E419T0B00 DPC-455 1C2F-AJA 7.3L E-350 DIESEL - AUTOMATIC CAL 3.55:1 VQAA4T5
2001 IQW1 1E419T0B05 DPC-455 1C2F-AJB 7.3L E-350 DIESEL - AUTOMATIC CAL 3.55:1 VQAA6T2
2001 IQW2 1E419T0B10 DPC-455 1C2F-AJC 7.3L E-350 DIESEL - AUTOMATIC CAL 3.55:1 VQAA7T2
2001 IQW3 1E419T0B11 DPC-455 1C2F-AJD 7.3L E-350 DIESEL - AUTOMATIC CAL 3.55:1 VQAA9T2
1999 JBG0 9DTA-BBA DPC-412 F81F-SA 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAD8BC
1999 JBG1 9DTA-BBB DPC-412 F81F-SB 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAE1B9
1999 JBG2 9DTA-BBC DPC-412 F81F-SC 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAE7B6
1999 JBG3 9DTA-BBD DPC-412 F81F-SD 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAE7B8
1999 JBG4 9DTA-BBE DPC-412 F81F-SE 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAE9B2
1999 JBG5 9DTA-BBF DPC-412 F81F-SF 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAE9BB
1999 JBG6 9DTA-BBF DPC-412 F81F-SG 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAF4B3
1999 JBG7 9DTA-BBF DPC-412 F81F-SH 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAF5B3
1999 JBG8 9DTA-BBF DPC-412 F81F-SJ 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VHAF7B2
1997 JKA0 7-89N-R00 DPC-311 F7TF-PA 7.3L F-SERIES DIESEL - MANUAL CAL FM30S02
1997 JKA1 7-89N-R00 DPC-311 F7TF-PB 7.3L F-SERIES DIESEL - MANUAL CAL FM30T502
1997 JKA2 7-89N-R00 DPC-311 F7TF-PC 7.3L F-SERIES DIESEL - MANUAL CAL FM30T510
1997 JKA3 7-89N-R10 DPC-311 F7TF-PD 7.3L F-250/350 DIESEL - MANUAL CAL VFAA1_02
1997 JKA4 7-89N-R11 DPC-311 F7TF-PE 7.3L F-250/350 DIESEL - MANUAL CAL VFAA104
2001 JLJ0 1F719W0A00 DPC-422 1C3F-ATA 7.3L P131 VRAA7W2
2001 JLJ1 1F719W0A10 DPC-422 1C3F-ATB 7.3L P131 VRAA7W3
1998 JRA0 9DTA-ANA DPC-405 F8UF-AB 7.3L E-350/450 DIESEL - AUTOMATIC 49S RYDER VGAE7NA
1998 JRA1 9DTA-ANB DPC-405 F8UF-AC 7.3L E-350/450 DIESEL - AUTOMATIC 49S RYDER VGAE9N4
1998 JRA2 9DTA-ANC DPC-405 F8UF-AD 7.3L E-350/450 DIESEL - AUTOMATIC 49S RYDER VGAE9NC
1999 JUK0 9DTA-BGB DPC-435 XU2F-AEA 7.3L E-350/450 DIESEL - AUTOMATIC SERVICE CAL VLAE4G3
1999 JUK1 9DTA-BGB DPC-435 XU2F-AEB 7.3L E-350/450 DIESEL - AUTOMATIC CAL VLAE4G5
2002 KEK2 2F719W0A06 7.3L F-250/350 DIESEL - AUTOMATIC 49S/CFFV
2002 KEK3 7.3L F-250/350 DIESEL - AUTOMATIC 49S/CFFV
2002 KEK5 7.3L F-250/350 DIESEL - AUTOMATIC 49S/CFFV
2001 KRK0 1F719P0B05 DPC-422 1C3F-AEA 7.3L F-450/550 DIESEL - AUTOMATIC CFF/LEV VRAA4P6
2001 KRK1 1F719P0B05 DPC-422 1C3F-AEB 7.3L F-450/550 DIESEL - AUTOMATIC CFF/LEV VRAA6P3
2001 KRK2 1F719P0B10 DPC-422 1C3F-AEC 7.3L F-450/550 DIESEL - AUTOMATIC CFF/LEV VRAA7P5
2001 KRK3 1F719P0B11 DPC-422 1C3F-AED 7.3L F-450/550 DIESEL - AUTOMATIC CFF/LEV VRAA7P6
1997 LJP0 7-90C-R10 DPC-315 F8UF-ALA 7.3L E-350 DIESEL - AUTOMATIC 49S/CANADA VEAB1_04
1998 LJP1 8-90C-R11 DPC-315 F8UF-ALB 7.3L E-350 DIESEL - AUTOMATIC 49S/CANADA VEAB202
1996 LKM0 6-90D-R00 DPC-202 F6UF-YA 7.3L E-SERIES DIESEL FAEF20M8
1996 LKM2 6-90D-R02 DPC-202 F6UF-YC 7.3L E-SERIES DIESEL FA20M0I
1996 LKM5 6-90D-RXX DPC-202 F6UF-YG 7.3L E-SERIES DIESEL VCAA0_0F
1996 LKM6 6-90D-R14 DPC-202 F6UF-YH 7.3L E-SERIES DIESEL VCAB0_06
2000 LSL0 0F729T0A00 DPC-422 XU7F-BA 7.3L P131 VNAAAT2
2000 LSL1 0F729T0A00 DPC-422 XU7F-BB 7.3L P131 VNAAAT3
1999 LVS0 9DTA-AVC DPC-422 XU2F-AAA 7.3L F-450/550/650 DIESEL - AUTOMATIC SERVICE 50S COLD WTR VJAE5V4
1999 LVS1 9DTA-AVC DPC-422 XU2F-AAB 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VJAE6V4
1999 LVS2 9DTA-AVC DPC-422 XU2F-AAC 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VJAE7V2
1999 LVS3 9DTA-AVC DPC-422 XU2F-AAD 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S COLD WTR VJAE7V3
1996 MIF0 6-90P-R00 DPC-202 F6TF-AXA 7.3L F-250/350 & E-350 DIESEL - AUTOMATIC CAL FAEF20J2
1996 MIF1 6-90P-RXX DPC-202 F6TF-AXB 7.3L F-250/350 & E-350 DIESEL - AUTOMATIC CAL FAEF20L4
1996 MIF2 6-90P-R01 DPC-2002 F6TF-AXC 7.3L F-250/350 & E-350 DIESEL - AUTOMATIC CAL FAEF20M4
1996 MIF4 6-90P-R02 DPC-202 F6TF-AXE 7.3L F-250/350 & E-350 DIESEL - AUTOMATIC CAL FA20M0E
1996 MIF5 6-90P-RXX DPC-202 F6TF-AXF 7.3L F-250/350 & E-350 DIESEL - AUTOMATIC CAL FA20N4
1996 MIF6 6-90P-R11 DPC-202 F6TF-AXG 7.3L F-250/350 & E-350 DIESEL - AUTOMATIC CAL FA20R02
1996 MIF7 6-90P-R12 DPC-202 F6TF-AXH 7.3L F-250/350 & E-350 DIESEL - AUTOMATIC CAL FA20R402
1996 MLE0 7-89A-R10 DPC-203 F7TF-SA 7.3L F-250/350 DIESEL - MANUAL VDAA0_04
1996 MLE1 7-89A-R11 DPC-203 F7TF-SB 7.3L F-250/350 DIESEL - MANUAL VDAB0_02
1999 MLU0 9DTA-AAA DPC-405 F8UF-AFA 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VGAD8A2
1999 MLU1 9DTA-AAB DPC-405 F8UF-AFB 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VGAE1A7
1998 MLU2 9DTA-AAC DPC-405 F8UF-AFC 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VGAE7A6
1998 MLU3 9DTA-AAD DPC-405 F8UF-AFD 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VGAE7A9
1998 MLU4 9DTA-AAE DPC-405 F8UF-AFE 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VGAE9A3
1998 MLU5 9DTA-AAF DPC-405 F8UF-AFF 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VGAE9AB
1999 MLU6 9DTA-AAF DPC-405 F8UF-AFG 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VGAF4A4
1998 MLU7 9DTA-AAF DPC-405 F8UF-AFH 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VGAF4A6
1997 MME0 7-90P-R00 DPC-312 F7TF-RA 7.3L F-250/350 DIESEL - AUTOMATIC CAL FA30S02
1997 MME1 7-90P-R00 DPC-312 F7TF-RB 7.3L F-250/350 DIESEL - AUTOMATIC CAL FA30T50C
1997 MME2 7-90P-R00 DPC-312 F7TF-RC 7.3L F-250/350 DIESEL - AUTOMATIC CAL FA30T50E
1997 MME3 7-90P-R10 DPC-312 F7TF-RD 7.3L F-250/350 DIESEL - AUTOMATIC CAL VEAA1_04
1997 MME4 7-90P-R11 DPC-312 F7TF-RE 7.3L F-250/350 DIESEL - AUTOMATIC CAL VEAB10E
1997 MME5 7-90P-R12 DPC-312 F7TF-RF 7.3L F-250/350 DIESEL - AUTOMATIC CAL VEAB10F
1997 MME6 7-90P-R13 DPC-312 F7TF-RG 7.3L F-250/350 DIESEL - AUTOMATIC CAL VEAB20A
1997 MME7 7-90P-R13 DPC-312 F7TF-RH 7.3L F-250/350 DIESEL - AUTOMATIC SERVICE CAL VEAB20B
2000 MNM0 0F729S0A00 DPC-422 XU7F-AA 7.3L P131 VNAAAS2
1999 MNM1 0F729S0A00 DPC-422 XU7F-AB 7.3L P131 VNAAAS3
2000 MQJ0 0L119Y0B11 DPC-452 YU7F-AA 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS/GPCM VNAB6Y2
1999 MRT0 9DTA-AUC DPC-422 XU2F-RA 7.3L F-450/550/650 DIESEL - AUTOMATIC SERVICE 49S COLD WTR VJAE5U5
1999 MRT1 9DTA-AUC DPC-422 XU2F-RB 7.3L F-450/550/650 DIESEL - AUTOMATIC 49S COLD WTR VJAE6U4
1999 MRT2 9DTA-AUC DPC-422 XU2F-RC 7.3L F-450/550/650 DIESEL - AUTOMATIC 49S COLD WTR VJAE7U2
1999 MRT3 9DTA-AUC DPC-422 XU2F-RD 7.3L F-450/550/650 DIESEL - AUTOMATIC 49S COLD WTR VJAE7U3
1999 MYA0 9DTA-BMA DPC-435 XC2F-BBA 7.3L E-350 DIESEL - AUTOMATIC CAL VMAA8M3
1999 MYA1 9DTA-BMA DPC-435 XC2F-BBB 7.3L E-350 DIESEL - AUTOMATIC SERVICE CAL VMAA8M5
1996 NAW0 6-90A-R00 DPC-202 F6TF-AYA 7.3L F-250/350 & ECONOLINE DIESEL - AUTOMATIC 49S/ALT/CAN FAEF20J4
1996 NAW1 6-90A-RXX DPC-202 F6TF-AYB 7.3L F-250/350 & ECONOLINE DIESEL - AUTOMATIC 49S/ALT/CAN FAEF20L2
1996 NAW2 6-90A-R01 DPC-202 F6TF-AYC 7.3L F-250/350 & ECONOLINE DIESEL - AUTOMATIC 49S/ALT/CAN FAEF20M2
1995 NAW4 6-90A-R02 DPC-202 F6TF-AYE 7.3L F-250/350 & ECONOLINE DIESEL - AUTOMATIC 49S/ALT/CAN FA20M0C
1996 NAW5 6-90A-RXX DPC-202 F6TF-AYF 7.3L F-250/350 & ECONOLINE DIESEL - AUTOMATIC 49S/ALT/CAN FA20N2
1996 NAW6 6-90A-R11 DPC-202 F6TF-AYG 7.3L F-250/350 & ECONOLINE DIESEL - AUTOMATIC 49S/ALT/CAN FA20P402
1999 NBD0 9DTM-AOA DPC-421 XC3F-LB 7.3L F-450/550/650 DIESEL - MANUAL 50S WARM WTR VKAE0O3
1999 NBD1 9DTM-AOA DPC-421 XC3F-LC 7.3L F-450/550/650 DIESEL - MANUAL 50S WARM WTR VKAE1O2
1999 NBD2 9DTM-AOB DPC-421 XC3F-LD 7.3L F-450/550/650 DIESEL - MANUAL 50S WARM WTR VKAE3Z3
1997 NFF0 8-90Q-R10 DPC-315 F8UF-AKA 7.3L E-350 DIESEL - AUTOMATIC ROAD-SPEED LTD VEAB1_0A
1998 NFF1 8-90Q-R11 DPC-315 F8UF-AKB 7.3L E-350 DIESEL - AUTOMATIC CAL VEAB208
1997 NFF2 8-90Q-R12 DPC-315 F8UF-AKC 7.3L E-350 DIESEL - AUTOMATIC CAL/RYDER VEAB20E
2001 NMC0 1F719N0B00 DPC-452 1C3F-ABA 7.3L F-250/350 DIESEL - AUTOMATIC CAL VRAA4N5
2001 NMC1 1F719N0B05 DPC-452 1C3F-ABB 7.3L F-250/350 DIESEL - AUTOMATIC CAL VRAA6N3
2001 NMC2 1F719N0B10 DPC-452 1C3F-ABC 7.3L F-250/350 DIESEL - AUTOMATIC CAL VRAA7N7
2001 NMC3 1F719N0B11 DPC-452 1C3F-ABD 7.3L F-250/350 DIESEL - AUTOMATIC CAL VRAA7N8
2002 NQW2 2L119Y0506 7.3L EXCURSION DIESEL - AUTOMATIC 50S
2002 NQW3 2L119Y0510 7.3L EXCURSION DIESEL - AUTOMATIC 50S
2002 NQW4 7.3L EXCURSION DIESEL - AUTOMATIC 50S
2002 NQW5 7.3L EXCURSION DIESEL - AUTOMATIC 50S
1999 NSU0 9DTA-BHA DPC-432 XC3F-SB 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VJAE0H5
1999 NSU1 9DTA-BHA DPC-432 XC3F-SC 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VJAE1H2
1999 NSU2 9DTA-BHB DPC-432 XC3F-SD 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VJAE3H2
1999 NVK0 9DTA-AUA DPC-422 XC3F-BB 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VJAE0U4
1999 NVK1 9DTA-AUA DPC-422 XC3F-BC 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VJAE1U4
1999 NVK2 9DTA-AUB DPC-422 XC3F-BD 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VJAE3U3
1999 NVK3 9DTA-AUC DPC-422 XC3F-EBD 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VJAE3U5
2000 NVK4 9DTA-AUD DPC-422 XC3F-BF 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VNAA8U5
2000 NVK5 0F729S0A00 DPC-422 XC3F-BG 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VNAA9S4
2002 NWM0 2F719S0A10 7.3L F-250/350 DIESEL - AUTOMATIC 49S
2002 PBY0 2F719T0A10 7.3L F-450/550 DIESEL - AUTOMATIC 50S
1997 PFY0 8-90D-R10 DPC-315 F8UF-AMA 7.3L E-350 DIESEL - AUTOMATIC ROAD-SPEED LTD VEAB1_06
1998 PFY1 8-90D-R11 DPC-315 F8UF-AMB 7.3L E-350 DIESEL - AUTOMATIC 49S/CAN VEAB204
2001 PMT0 1F719S0A00 DPC-422 1C3F-ZA 7.3L F-250/350 DIESEL - AUTOMATIC 49S VRAA4S4
2001 PMT1 1F719S0A05 DPC-422 1C3F-ZB 7.3L F-250/350 DIESEL - AUTOMATIC 49S VRAA6S3
2001 PMT2 1F719S0A10 DPC-422 1C3F-ZC 7.3L F-250/350 DIESEL - AUTOMATIC 49S VRAA7S5
2001 PMT3 1F719S0A11 DPC-422 1C3F-ZD 7.3L F-250/350 DIESEL - AUTOMATIC 49S VRAA7S6
1997 PPB0 7-90C-R00 DPC-315 F7UF-AFA 7.3L E & F-250/350 DIESEL FA30S04
1997 PPB1 7-90C-R00 DPC-315 F7UF-AFB 7.3L E & F-250/350 DIESEL FA30T506
1997 PPB2 7-90C-R10 DPC-315 F7UF-AFC 7.3L E-350 DIESEL - AUTOMATIC FA30T812
1996 PRE0 6-90B-R00 DPC-202 F6TF-AZA 7.3L F-SUPER DUTY DIESEL - AUTOMATIC 50S/ALT/CAN FASD20J6
1996 PRE1 6-90B-RXX DPC-202 F6TF-AZB 7.3L F-SUPER DUTY DIESEL - AUTOMATIC 50S/ALT/CAN FASD20L6
1996 PRE2 6-90B-R01 DPC-202 F6TF-AZC 7.3L F-SUPER DUTY DIESEL - AUTOMATIC 50S/ALT/CAN FASD20M6
1995 PRE4 6-90B-R02 DPC-202 F6TF-AZE 7.3L F-SUPER DUTY DIESEL - AUTOMATIC 50S/ALT/CAN FA20M0G
1996 PRE5 6-90B-RXX DPC-202 F6TF-AZF 7.3L F-SUPER DUTY DIESEL - AUTOMATIC 50S/ALT/CAN FA20N6
1996 PRE6 6-90B-R11 DPC-202 F6TF-AZG 7.3L F-SUPER DUTY DIESEL - AUTOMATIC 50S/ALT/CAN FA20P406
1995 PRY0 5-90B-R00 DPC-202 F5TF-BHA 7.3L F-SUPER DUTY DIESEL - AUTOMATIC FDASD10D
1995 PRY2 5-90B-R00 DPC-202 F5TF-BHC 7.3L F-SUPER DUTY DIESEL - AUTOMATIC FASD10E2
1995 PRY3 5-90B-R00 DPC-202 F5TF-BHD 7.3L F-SUPER DUTY DIESEL - AUTOMATIC FASD10I1
1995 PRY4 5-90B-R00 DPC-202 F5TF-BHE 7.3L F-SUPER DUTY DIESEL - AUTOMATIC FASD10J1
1995 PRY5 5-90B-R00 DPC-202 F5TF-BHF 7.3L F-SUPER DUTY DIESEL - AUTOMATIC FASD10J8
1999 PTH0 9DTA-BAA DPC-415 F8UF-AGA 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VGAD8A4
1999 PTH1 9DTA-BAB DPC-415 F8UF-AGB 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VGAE1AB
1998 PTH2 9DTA-BAC DPC-415 F8UF-AGC 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VGAE7A4
1998 PTH3 9DTA-BAD DPC-415 F8UF-AGD 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VGAE7AZ
1998 PTH4 9DTA-BAE DPC-415 F8UF-AGE 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VGAE9A2
1998 PTH5 9DTA-BAF DPC-415 F8UF-AGF 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VGAE9A8
1999 PTH6 9DTA-BAF DPC-415 F8UF-AGG 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VGAF4A5
1998 PTH7 9DTA-BAF DPC-415 F8UF-AGH 7.3L E-350/450 DIESEL - AUTOMATIC CAL NON-RYDER VGAF4A7
1999 QEK0 9DTM-ANB DPC-421 XU2F-UA 7.3L F-250/350 DIESEL - MANUAL SERVICE 49S WARM WTR VKAE4N5
1999 QEK1 9DTM-ANB DPC-421 XU2F-UB 7.3L F-250/350 DIESEL - MANUAL 49S WARM WTR VKAE4N7
2002 QLJ0 2F719N0B00 DPC-492 2C3F-HA 7.3L F-250/350 DIESEL - AUTOMATIC CAL TNAA2N3
2002 QLJ1 2F719N0B05 DPC-492 2C3F-HB 7.3L F-250/350 DIESEL - AUTOMATIC CAL TNAA3N4
2002 QLJ2 2F719N0B06 DPC-492 2C3F-HC 7.3L F-250/350 DIESEL - AUTOMATIC CAL TNAA4N2
2002 QLJ3 2F719N0B10 DPC-492 2C3F-HD 7.3L F-250/350 DIESEL - AUTOMATIC CAL TNAA5N5
2002 QLJ4 2F719N0B11 DPC-492 2C3F-HE 7.3L F-250/350 DIESEL - AUTOMATIC CAL TNAA5N7
2002 QLJ5 DPC-492 2C3F-HF 7.3L F-250/350 DIESEL - AUTOMATIC CAL
1999 QWL0 9DTM-BFA DPC-431 XC3F-MB 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VKAE0F5
1999 QWL1 9DTM-BFA DPC-431 XC3F-MC 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VKAE1F2
1998 QWL2 9DTM-BFB DPC-431 XC3F-MD 7.3L F-250/350 DIESEL - MANUAL CAL WARM WTR VKAE3F2
1999 RCU0 9DTA-AZA DPC-425 XC2F-BAA 7.3L E-350/450 DIESEL - AUTOMATIC 49S R/C VMAA8Z3
1999 RCU1 0E419S0A00 DPC-425 XC2F-BAB 7.3L E-350/450 DIESEL - AUTOMATIC CACKLE FIX 49S R/C VMAA8S5
2002 RDW0 2F710O0A10 7.3L F-450/550 DIESEL - AUTOMATIC CFF/LEV
1999 RXM0 9DTA-ASC DPC-422 XU2F-ABA 7.3L F-450/550/650 DIESEL - AUTOMATIC SERVICE 50S WARM WTR VJAE5S2
1999 RXM1 9DTA-ASC DPC-422 XU2F-ABB 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VJAE6S4
1999 RXM2 9DTA-ASC DPC-422 XU2F-ABC 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VJAE7S2
1999 RXM3 9DTA-ASC DPC-422 XU2F-ABD 7.3L F-450/550/650 DIESEL - AUTOMATIC 50S WARM WTR VJAE7S3
1999 SBJ0 9DTM-BGB DPC-431 XU2F-SA 7.3L F-250/350 DIESEL - MANUAL SERVICE CAL COLD WTR VKAE4G7
1999 SBJ1 9DTM-BGB DPC-431 XU2F-SB 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VKAE4G9
2000 SBR0 0E419R0B10 DPC-455 YC2F-ATA 7.3L E-350 DIESEL - AUTOMATIC CAL R/C VMAB1R3
2000 SBR1 0E419R0B11 DPC-455 YC2F-ATB 7.3L E-350 DIESEL - AUTOMATIC CAL R/C VMAB2R3
2000 SBR2 0E419R0B12 DPC-455 YC2F-ATC 7.3L E-350 DIESEL - AUTOMATIC CACKLE FIX CAL R/C VMAB6R2
2001 SKN0 1F729N0B00 DPC-471 1C3F-AAA 7.3L F-250/350 DIESEL - MANUAL CAL VSAA2MA
2001 SKN1 1F729M0B05 DPC-471 1C3F-AAB 7.3L F-250/350 DIESEL - MANUAL CAL VSAA4M9
1995 SOD1 5-89K-RXX DPC-203 F5TF-BTB 7.3L F-SERIES DIESEL - MANUAL FMEF10E2
1995 SOD2 5-89K-RXX DPC-203 F5TF-BTC 7.3L F-SERIES DIESEL - MANUAL FMEF10H0
1995 SOD3 5-89K-RXX DPC-203 F5TF-BTD 7.3L F-SERIES DIESEL - MANUAL FMEF10I1
1994 SOD4 5-89K-RXX DPC-203 F5TF-BTE 7.3L F-SERIES DIESEL -MANUAL FMEF10J1
1995 SOD5 5-89K-RXX DPC-203 F5TF-BTF 7.3L F-SERIES DIESEL -MANUAL FMEF10J3
1997 SXL0 7-90K-R00 DPC-315 F7UF-AGA 7.3L E-SUPER DUTY DIESEL - AUTOMATIC FA30S06
1997 SXL1 7-90K-R00 DPC-315 F7UF-AGB 7.3L E-SUPER DUTY DIESEL - AUTOMATIC FA30T50A
1997 SXL2 7-90K-R10 DPC-315 F7UF-AGC 7.3L E-SUPER DUTY DIESEL - AUTOMATIC FA30T816
1999 SZT0 9DTA-AOA DPC-425 XC2F-APB 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VLAE0O4
1999 SZT2 9DTA-AOB DPC-425 XC2F-APC 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VLAE3O3
2000 SZT3 9DTA-AOC DPC-425 XC2F-APD 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VMAA8O5
2000 SZT4 9DTA-AOD DPC-425 XC2F-APE 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER VMAA8O7
2000 SZT5 0E419M0A00 DPC-425 XC2F-APF 7.3L E-350/450 DIESEL - AUTOMATIC 49S NON-RYDER CACKLE FIX VMAA8M9
1996 TDE0 7-90A-R10 DPC-202 F7TF-TA 7.3L F-250/350 DIESEL - AUTOMATIC VCAA0_08
1996 TDE1 7-90A-R10 DPC-202 F7TF-TB 7.3L F-250/350 DIESEL - AUTOMATIC VCAB0_02
1995 TEE0 5-90A-RXX DPC-202 F5TF-BJA 7.3L E & F-SERIES DIESEL - AUTOMATIC FDAEF10D
1995 TEE2 5-90A-RXX DPC-202 F5TF-BJC 7.3L E & F-SERIES DIESEL - AUTOMATIC FAEF10E2
1995 TEE3 5-90A-RXX DPC-202 F5TF-BJD 7.3L E & F-SERIES DIESEL - AUTOMATIC FAEF10H0
1995 TEE4 5-90A-RXX DPC-202 F5TF-BJE 7.3L E & F-SERIES DIESEL - AUTOMATIC FAEF10I1
1995 TEE5 5-90A-RXX DPC-202 F5TF-BJF 7.3L E & F-SERIES DIESEL - AUTOMATIC FAEF10J1
1995 TEE5 5-90A-RXX DPC-202 F5TF-BJF 7.3L E & F-SERIES DIESEL - AUTOMATIC FAEF10J4
1998 TYB0 9DTA-BCA DPC-415 F8UF-BB 7.3L E-350/450 DIESEL - AUTOMATIC CAL RYDER VGAE7C7
1998 TYB1 9DTA-BCB DPC-415 F8UF-BC 7.3L E-350/450 DIESEL - AUTOMATIC CAL RYDER VGAE9C2
1998 TYB2 9DTA-BCC DPC-415 F8UF-BD 7.3L E-350/450 DIESEL - AUTOMATIC CAL RYDER VGAE9CB
2000 UKN0 0F719N0B10 DPC-452 XC3F-DDA 7.3L F-250/350 DIESEL - AUTOMATIC CAL R/C VNAB1N2
2000 UKN1 0F719N0B11 DPC-452 XC3F-DDB 7.3L F-250/350 DIESEL - AUTOMATIC CACKLE FIX CAL R/C VNAB5N3
1999 UYQ0 9DTA-AOB DPC-425 XU2F-ADA 7.3L E-350/450 DIESEL - AUTOMATIC SERVICE 49S VLAE402
1999 UYQ1 9DTA-AOB DPC-425 XU2F-ADB 7.3L E-350/450 DIESEL - AUTOMATIC 49S VLAE4O4
1999 VCQ0 9DTA-BEA DPC-412 F81F-DB 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VHAD8EA
1999 VCQ1 9DTA-BEB DPC-412 F81F-DC 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VHAE1EA
1999 VCQ2 9DTA-BEC DPC-412 F81F-DD 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VHAE7E6
1999 VCQ3 9DTA-BED DPC-412 F81F-DE 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VHAE7E8
1999 VCQ4 9DTA-BEE DPC-412 F81F-DF 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VHAE9E2
1999 VCQ5 9DTA-BEF DPC-412 F81F-DG 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VHAE9E9
1999 VCQ6 9DTA-BEF DPC-412 F81F-DH 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR CHAF4E6
1999 VCQ7 9DTA-BEF DPC-412 F81F-DJ 7.3L F-250/350 DIESEL - AUTOMATIC PT # CHGD CAL COLD WTR VHAF5E4
1999 VCQ8 9DTA-BEF DPC-412 F81F-DK 7.3L F-250/350 DIESEL - AUTOMATIC CAL COLD WTR VHAF7E2
2002 VDH0 2F719S0A00 DPC-462 2C3F-DA 7.3L F-250/350 DIESEL - AUTOMATIC 49S TNAA2S3
2002 VDH1 2F719S0A05 DPC-462 2C3F-DB 7.3L F-250/350 DIESEL - AUTOMATIC 49S TNAA3S3
2002 VDH2 2F719S0A06 DPC-462 2C3F-DC 7.3L F-250/350 DIESEL - AUTOMATIC 49S TNAA4S2
2002 VDH3 2F719S0A10 DPC-462 2C3F-DD 7.3L F-250/350 DIESEL - AUTOMATIC 49S TNAA5S5
2002 VDH4 2F719S0A11 DPC-462 2C3F-DE 7.3L F-250/350 DIESEL - AUTOMATIC 49S TNAA5S8
2002 VDH5 2F719S0A?? DPC-462 2C3F-DF 7.3L F-250/350 DIESEL - AUTOMATIC 49S TNAA?S?
2002 VDU2 2F719P0A06 7.3L F-450/550 DIESEL - AUTOMATIC CFF/LEV
2002 VDU3 7.3L F-450/550 DIESEL - AUTOMATIC CFF/LEV
2002 VDU5 7.3L F-450/550 DIESEL - AUTOMATIC CFF/LEV
2001 VLB0 1E419S0A00 DPC-425 1C2F-AGA 7.3L E-SERIES DIESEL - AUTOMATIC 49S 3.55:1 VQAA4S4
2001 VLB1 1E419S0A05 DPC-425 1C2F-AGB 7.3L E-SERIES DIESEL - AUTOMATIC 49S 3.55:1 VQAA6S2
2001 VLB2 1E419S0A10 DPC-425 1C2F-AGC 7.3L E-SERIES DIESEL - AUTOMATIC 49S 3.55:1 VQAA7S2
2001 VLB3 1E419S0A11 DPC-425 1C2F-AGD 7.3L E-SERIES DIESEL - AUTOMATIC 49S 3.55:1 VQAA9S2
1999 VRP0 9DTM-AOB DPC-421 XU2F-XA 7.3L F-450/550/650 DIESEL - MANUAL SERVICE 50S WARM WTR VKAE4O4
1999 VRP1 9DTM-AOB DPC-421 XU2F-XB 7.3L F-450/550/650 DIESEL - MANUAL 50S WARM WTR VKAE4O6
1999 VXY0 9DTM-AQA DPC-421 XC3F-KB 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VKAE0Q3
1999 VXY1 9DTM-AQA DPC-421 XC3F-KC 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VKAE1Q2
1999 VXY2 9DTM-AQB DPC-421 XC3F-KD 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VKAE3Q3
2000 VXY3 9DTM-AQC DPC-421 XC3F-KF 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VOAA7Q5
2000 VXY4 0F719R0A00 DPC-421 XC3F-KG 7.3L F-450/550/650 DIESEL - MANUAL 50S COLD WTR VOAA8R4
2000 WWV0 9DTA-BKC DPC-432 XU7F-DA 7.3L P131 DIESEL VNAAAK2
2000 WWV1 9DTA-BKC DPC-432 XU7F-DB 7.3L P131 DIESEL VNAAAK3
1999 XLE0 9DTA-AJA DPC-402 F81F-BB 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VHAD8J2
1999 XLE1 9DTA-AJB DPC-402 F81F-BC 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VHAE1JF
1999 XLE2 9DTA-AJC DPC-402 F81F-BD 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VHAE7J5
1999 XLE3 9DTA-AJD DPC-402 F81F-BE 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VHAE7J9
1999 XLE4 9DTA-AJE DPC-402 F81F-BF 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VHAE9J2
1999 XLE5 9DTA-AJF DPC-402 F81F-BG 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VHAE9JC
1999 XLE6 9DTA-AJF DPC-402 F81F-BH 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VHAF4J5
1999 XLE7 9DTA-AJF DPC-402 F81F-BJ 7.3L F-250/350 DIESEL - AUTOMATIC PART # CHGD 49S COLD WTR VHAF5J3
1999 XLE8 9DTA-AJF DPC-402 F81F-BK 7.3L F-250/350 DIESEL - AUTOMATIC 49S COLD WTR VHAF7J2
2000 XPC4 0F719Q0A00 DPC-421 XC3F-AG 7.3L F-250/350 DIESEL - MANUAL 49S R/C CACKLE FIX VOAA8Q4
1999 XWF0 9DTA-BHB DPC-432 XU2F-ACA 7.3L F-250/350 DIESEL - AUTOMATIC SERVICE CAL WARM WTR VJAE5H2
1999 XWF1 9DTA-BHB DPC-432 XU2F-ACB 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VJAE6H4
1999 XWF2 9DTA-BHB DPC-432 XU2F-ACC 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VJAE7H2
1999 XWF3 9DTA-BHB DPC-432 XU2F-ACD 7.3L F-250/350 DIESEL - AUTOMATIC CAL WARM WTR VJAE7H3
1996 YBT0 7-90J-R10 DPC-202 F7TF-UB 7.3L F-SUPER DUTY DIESEL - AUTOMATIC VCAA0_0E
1996 YBT1 7-90J-R11 DPC-202 F7TF-UB 7.3L F-SUPER DUTY DIESEL - AUTOMATIC VCAB0_04
1997 YCZ0 7-90N-R00 DPC-315 F7UF-AHA 7.3L E-350 DIESEL - AUTOMATIC FA30S08
1997 YCZ1 7-90N-R00 DPC-315 F7UF-AHB 7.3L E-350 DIESEL - AUTOMATIC FA30T502
1997 YCZ2 7-90N-R00 DPC-315 F7UF-AHC 7.3L E-350 DIESEL - AUTOMATIC FA30T50G
1997 YCZ3 7-90N-R10 DPC-315 F7UF-AHD 7.3L E-350 DIESEL - AUTOMATIC FA30T814
1999 YEV0 9DTA-ARC DPC-422 XU2F-ZA 7.3L F-250/350 DIESEL - AUTOMATIC SERVICE 49S WARM WTR VJAE5R3
1999 YEV1 9DTA-ARC DPC-422 XU2F-ZB 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VJAE6R4
1999 YEV2 9DTA-ARC DPC-422 XU2F-ZC 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VJAE7R2
1999 YEV3 9DTA-ARC DPC-422 XU2F-ZD 7.3L F-250/350 DIESEL - AUTOMATIC 49S WARM WTR VJAE7R3
2000 YLE0 0F719P0B11 DPC-422 YC3F-BCA 7.3L F-450/550 DIESEL - AUTOMATIC CFFV R/C VNAB1P6
2000 YLE1 0F719P0B12 DPC-422 YC3F-BCB 7.3L F-450/550 DIESEL - AUTOMATIC CACKLE FIX CFFV R/C VNAB5P3
2000 YSE0 0L119Y0B07 DPC-432 YU7F-BA 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS VNAAAY2
2000 YSE1 0L119Y0B07 DPC-432 YU7F-BB 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS VNAAAY3
1995 ZAA0 5-90C-RXX DPC-202 F5FF-XA 7.3L E-350/CUTAWAY DIESEL - AUTOMATIC DSO FAEF10J2
1995 ZAA1 5-90C-RXX DPC-202 F5FF-XB 7.3L E-350/CUTAWAY DIESEL - AUTOMATIC DSO FARD10J6
1999 ZDR0 9DTM-BEA DPC-411 F81F-CB 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VIAD8E6
1999 ZDR1 9DTM-BEB DPC-411 F81F-CC 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VIAE1E7
1999 ZDR2 9DTM-BEC DPC-411 F81F-CD 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VIAE7E3
1999 ZDR3 9DTM-BED DPC-411 F81F-CE 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VIAE9E2
1999 ZDR4 9DTM-BED DPC-411 F81F-CF 7.3L F-250/350 DIESEL - MANUAL CAL COLD WTR VIAF3E4
1999 ZDR5 9DTM-BED DPC-411 F81F-CG 7.3L F-250/350 DIESEL - MANUAL SERV FIX CAL COLD WTR VIAF3E7
1999 ZHL0 9DTM-APB DPC-421 XU2F-PA 7.3L F-450/550/650 DIESEL - MANUAL SERVICE 49S COLD WTR VKAE4P6
1999 ZHL1 9DTM-APB DPC-421 XU2F-PB 7.3L F-450/550/650 DIESEL - MANUAL 49S COLD WTR VKAE4P8
2002 ZRE2 2F729M0506 7.3L F-250/350 DIESEL - MANUAL CAL
2002 ZRE3 7.3L F-250/350 DIESEL - MANUAL CAL
2002 ZRE4 2F729M0510 7.3L F-250/350 DIESEL - MANUAL CAL
2001 ZXG0 1F729R0A00 DPC-441 1C3F-ACA 7.3L F-450/550 DIESEL VSAA2RB
2001 ZXG1 1F729R0A05 DPC-411 1C3F-ACB 7.3L F-450/550 DIESEL VSAA4R9
2000 ZYS2 0L119Y0B00 DPC-432 YC3F-ARC 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS VNAA6Y3
2000 ZYS3 0L119Y0B05 DPC-432 YC3F-ARD 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS VNAA7Y6
2000 ZYS4 0L119Y0B06 DPC-432 YC3F-ARE 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS VNAA7YA
2000 ZYS5 0L119Y0B07 DPC-432 YC3F-ARF 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS VNAA8Y5
2000 ZYS6 0L119Y0B07 DPC-432 YC3F-ARG 7.3L EXCURSION DIESEL - AUTOMATIC 50S - EPATS VNAA9Y2
Old 02-05-2015, 02:42 PM   #10
E350's Avatar
Re: Need a PCM
Well alrighty then! I see 2002 in there so when I get a chance I will check for my van's pcm number and compare it with your list.
Thanks for posting!
