Old 08-28-2015, 10:49 AM   #1
BrianBlair's Avatar
Rear Axle seal issue.....
I(mainly my mechanic) noticed what looks like the start of a seal failure of the rear axle seal. See attached photo....I did my best to capture it.
Question....is this something that should be dealt with immediately?
I'm already having a number of things done and was thinking of saving this for a future visit if it isn't completely dire.
BB
Old 08-28-2015, 11:07 AM   #2
Re: Rear Axle seal issue.....
I think I see metal shavings? If so, yes! Get it checked out ASAP. It looks like you have a semi-float axle? A common reason for a leaky seal is play from either bad bearings, or sometimes even a worn axle shaft. Even if everything else is fine, it'll still end up oiling your parking brake shoes.
Old 08-28-2015, 01:46 PM   #3
BrianBlair's Avatar
Thanks for the info. I went ahead and had them dig into it.
BB
Old 09-05-2015, 07:47 PM   #4
UJOINT's Avatar
Yea, full inspection right away.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
