Old 03-20-2010, 05:37 PM   #1
jtolittle's Avatar
upgrading to 2008 front body style ??
Hello,
anybody with a pre 2008 ford E-series upgraded to the newer grille/hood/lights?
Is it fairly easy to do? Does it match good?
Maybe a little bit of fabrication for the lights brackets...
JT
jtolittle is offline   Reply With Quote
Old 03-20-2010, 06:40 PM   #2
Re: upgrading to 2008 front body style ??
I've seen several vans with this change. Probably a bunch of money for new fenders, hood, grill, lights, some supporting stucture, etc. If you are repairing a wreck, it is probably a wash, new vs. old style parts.
Certainly doable.
Old 03-20-2010, 09:53 PM   #3
bettyford's Avatar
Send a message via MSN to bettyford
Mine is a 93 and it has been up graded with the newer mirrors, head lights, and grill.everything fit easily.
These are the best shots I have of that.
Hope it helps
Ron
Going where most dont
"one day at a time"
bettyford is offline   Reply With Quote
Old 03-20-2010, 10:07 PM   #4
I like the older style look better than the newer one. I guess I just have to get used to it.
Nice van Betty, love the SD mirrors!!!
Sent from my iPhone using Tapatalk
2010 EB E-250 2wd Homebrew
Transformer style build w/AV lift!
floorguy_724 is offline   Reply With Quote
Old 03-20-2010, 10:24 PM   #5
Greg In Austin's Avatar
Betty are you sure that is the 2008 setup ???
Greg in Austin
Old 03-20-2010, 11:14 PM   #6
bettyford's Avatar
No i think its from a 2004. i guess i miss read, sorry. if you want to go that new it will not fit and you will need to do a lot of work to get it right. 1992-2006 are interchangeable.
Ron
"one day at a time"
Old 03-22-2010, 12:32 AM   #7
Yes, the conversion can be done.
Need new fenders, hood, hood support, bumper, headlights.
Old 03-22-2010, 06:29 PM   #8
Jeffrey's Avatar
Why would you want to? The newer ones are butt ugly. Money to burn?
YOMV.
Old 03-26-2010, 06:38 AM   #9
spomo1's Avatar
Ron. I have a 98 and have been looking at doing the mirror upgrade to the same mirrors you put on. I was told that there was a 3 bolt vs 4 bolt issue? Is correct? I also want to put the interior grab handle on but cant find any existing bolts in the A pillar.
Terry
spomo1 is offline   Reply With Quote
Old 08-13-2010, 06:32 PM   #10
Ridge's Avatar
YOMV.
I'm thinking of doing this update as well. If I'm not mistaken, it looks like the newer front clip extends the front out a little bit...maybe enough for an inner-cooler and a 12 valve Cummins.
Ridge is offline   Reply With Quote
"Campy"
campy
97 Eco
MTDave
