Old 09-22-2012, 08:30 PM   #1
spurious's Avatar
Late Model Front End Conversion
It has been somewhat in question if you can take early model 1993-2007 van and convert it to a late model 2008-2012 front end.
The answer is YES.
Without going into a step by step procedure this is a straight forward bolt on procedure. So no more guessing, it can be done.
Before
spurious is offline   Reply With Quote
Old 09-22-2012, 08:43 PM   #2
OG1
Re: Late Model Front End Conversion
Nice! I have been wondering about this. Did you have to change the core support too?
OG1 is offline   Reply With Quote
Old 09-22-2012, 08:57 PM   #3
spurious's Avatar
You don't have to change the core support. Although on the core support there is a piece that bolts on, it was replaced because hood latches are different. You loose two mounting bolts on each side of the top of the fenders otherwise everything bolts right up. I might add there are a few places to drill holes for the difference of Mounting configurations of certain brackets. But when doing the conversion you'll see it's very minimal....
You also need to add a late model hood prop.
Old 09-23-2012, 12:04 PM   #4
depark's Avatar
That looks AWSOME!! I have always liked the new van front end and have wondered if it was possible to swap it out. Thanks for answering the question for everyone. I'm sure there are many others that have wondered about it also. Are all the parts new and about how much did it cost you to do the swap?
Darryl
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
Old 09-23-2012, 02:07 PM   #5
SCBrian's Avatar
Nice to see you active again on the forum. Your original build is one of my favorites. Care to share your plans for this van? I like the wheel and tire combo. Can you post the details?
2001 E350 V10 Homebrew
My Build Thread
SCBrian is offline   Reply With Quote
Old 09-23-2012, 06:42 PM   #6
BIGVANS's Avatar
Yes, it's been done many times before. Basically ALL the metal from the "A" pillars forward and some mods to the wiring harness.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 09-23-2012, 09:24 PM   #7
spurious's Avatar
Thanks, I keep an eye on the forum and there's been a lot great builds since. Great work being done out there. Hopefully I was able to inspire anyone who read in some small way.
My plans are pretty simple for this van. I will either convert to 4wd via ujoint or a 2wheel lift. Not sure as of yet. The interior will be simple, I use it on a daily basis so very plain. Factory crew seat insulated and carpet through out.
The parts for my conversion were mostly recycled, there were a few parts that were ordered through ford. The cost will truly depend on what you can source the parts for.
I understand the conversion has been done before, I searched many times to find someone who actually admits to doing it. There has been one time that it was mentioned he had done it but very vague. The only wiring that was altered would be the difference in headlight configuration. Mine I chose to use the sealed beams so original factory plug was used. If you use composite headlights the three wire headlight plug will need to be changed. Otherwise no other wiring will need to be done.
Old 09-24-2012, 08:59 PM   #8
BIGVANS's Avatar
GREAT Job!
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 10-07-2012, 10:23 PM   #9
Hi I was wonder the same thing!! can you list all the parts that you used.. beside the obvious!!
I will really appreciated!!
vanvan is offline   Reply With Quote
Old 10-08-2012, 11:22 AM   #10
schluchtenflitzer's Avatar
great job!
i am also interessted in a list what parts are needed!
What i am also thinking for is to change the dashbord also to the newer one...uhhh i love it!
did anyone know if this also can be done and what you have to do?
I am expecting a lot of work?!
www.Dieda-unterwegs.net
