Old 10-20-2014, 04:41 PM   #1
Trailer
I'm wondering if you guys have any suggestions on a good trailer for hauling bikes and maybe a couple other things.
theblackdog123 is offline   Reply With Quote
Old 10-20-2014, 05:43 PM   #2
Re: Trailer
Enclosed or open/ flatbed? How many bikes (I'm assuming motorcycles?) What kind of other things? How often do you plan on towing it? Will you be taking it offroad? What is your budget? Those answers should get us started!
Old 10-20-2014, 05:48 PM   #3
Re: Trailer
I am looking for an open trailer that can hold two bikes. (Actual bikes you have to pedal) It will be taken off-road and be used very often.
Old 10-20-2014, 05:59 PM   #4
Re: Trailer
What kind of bikes??? All of these are expensive. I'm sure you can have something custom done if you don't need all the camping stuff and if you mean dirt bikes size and loading become an issue.
http://www.schuttindustries.com/Consumer.aspx
http://www.adrenalincampers.com/
http://www.manleyorv.com/trailers/morv-original.html
http://adventuretrailers.com/trailers/
http://www.tentrax.com/
http://www.campausa.com/#!standardcub/c1qmm
http://www.vmioffroad.com/products/xten ... ilers.html
http://moabaz.com/
But if you go through this section there is a guy in Colorado IIRC that does a nice job. I'll post the link if I find it.
Old 10-20-2014, 06:01 PM   #5
Re: Trailer
I will be going off-road pretty often and I mean a trailer I can stick two bikes on (normal bikes your have to pedal), and a few other things.
Old 10-20-2014, 06:13 PM   #6
Re: Trailer
Yeah, I'd think most of those companies can outfit the top to hold Mtn bikes and what not. Just depends on what you want to spend. I have a SMB trailer that came with bars to hold bikes.
Old 10-20-2014, 06:19 PM   #7
Re: Trailer
Here you go.
http://www.pikespeaktrailers.com/
Never priced his stuff but it might be in the link here:
viewtopic.php?f=6&t=5926
Old 10-20-2014, 06:34 PM   #8
Re: Trailer
I'd hate to buy a single purpose trailer, when for a little more investment, you can have a multifunction trailer.
Some other sources. Some more off road capable than others:
http://www.amazon.com/Lifetime-Deluxe-T ... B008KZH190
http://manleyorv.com/trailers/morv-explore.html
http://outlandertrailers.us/OT/Sherpa_II.html
http://www.rugertrailers.com/
And this may be the one Daveb is thinking about. Their website appears out of date, so I'm not sure what that means.
viewtopic.php?f=6&t=5926&hilit=pikes+trailer
Old 10-20-2014, 07:14 PM   #9
Re: Trailer
These little guys from tractor supply might fit the bill for you and they are a hell of a lot nicer than those from harbor freight tools: http://m.tractorsupply.com/en/store/car ... _vc=-10005 With a simple spring over lift and a bigger tire/wheel combo they should go anywhere you need offroad. They also sell a 4x6 version without the ramp gate.
Old 10-23-2014, 10:12 AM   #10
4MacFam's Avatar
Re: Trailer
I'm really enjoying my Xventure by Schutt Ind. But then I wanted something to be multi purpose. The camping fun is obvious, but I've also used it to haul lots of stuff. I just filled it with 2000 lbs of gravel, hauled 4x8 sheets of plywood (trailer gate down), and I have ramps to transport a motorcycle or atv.
The tires and wheels match my rig so I don't have to carry a spare, but I have one to thrown in the trailer if need be. I'm about to rotate all eight tires now, but haven't decided on what to do with the TPS system. Bikes hang off the back or I can put them in the trailer.
20 gallon water tank below the trailer
On demand propane water heater
20lb propane tank on front
storage locker up front has Goal Zero Yeti 400, fits 2 5 gallon gas cans, and a D/C frig cooler. They even have a spot to mount an air compressor.
Steven McKenzie
Madison, WI
2013 E350 EB-44, V10 6.8ltr
Toyo LT285/70 R17
