Old 06-17-2014, 06:19 PM   #1
WANTED: full float axle w/ 4.10's
I'm looking for a complete rear axle from a 2000 or newer (disc brake) Ford E350 van. Must be full float dana 60 (or 70) with 4.10 gears and limited slip. I want it to bolt into my van, so no other versions will be considered. Hopefully within reasonable driving distance of 93454. Let me know if you've got one.
Jay
Old 06-18-2014, 05:18 PM   #2
Re: WANTED: full float axle w/ 4.10's
Not exactly what you are asking for but if you wanted to dually it, here's one:
http://sfbay.craigslist.org/sfc/pts/4523735921.html
Old 06-19-2014, 10:50 AM   #3
ANZAC's Avatar
UJOINT had one like this listed a few months ago, you might check in with him.
Sportsmobile-less.
Old 07-02-2014, 02:13 PM   #4
Still looking. If you have one/ know of one that is not limited slip I would still consider it. If it does not have 4.10's I may still consider it as long as it is cheap!
I thought I had one lined up so I had a friend make a detour to pick it up for me in Visalia. "Yep, dana 60 full float with disc brakes and 4.10's from a 2001 econoline, I'd take $250 for it" Turned out to be a superduty axle!
I'm beginning to question if swapping to rear disc brakes is worth the trouble?
Old 07-02-2014, 07:23 PM   #5
.. could the candidates below be built up to what you want?
http://sacramento.craigslist.org/pts/4545392468.html
http://sacramento.craigslist.org/pts/4538987434.html
Old 07-02-2014, 07:52 PM   #6
The factory Ford disc brakes are the biggest reason that I am even looking for a new axle assembly, getting factory installed 4.10 and L/S (without having to pay extra to "upgrade") at the same time would help justify the expense of the swap. I currently have a drum brake dana 60 full float with 3.55's and open diff, so if I can't find a good price on the disc brake version soon, I will just start building my current one. Thank you for keeping an eye out though, I really do appreciate it!
Old 07-17-2014, 03:47 PM   #7
mikracer's Avatar
Saw this on the SLO craigs. Not sure what its out of though...
http://slo.craigslist.org/pts/4543306856.html
Old 07-17-2014, 04:42 PM   #8
That's a good deal! I just called and it is out of an E350 4x4... unfortunately it's a semi-float, I don't think the brakes will swap with the full float (I could be wrong) otherwise I'd buy it for parts. He said the LS only has ~10k miles on it.
Old 07-17-2014, 04:49 PM   #9
mikracer's Avatar
Bummer. Was hoping you could find something local!
