Old 07-29-2014, 01:14 PM   #1
2003 E350 4X4 Window Camper Van plus Solar Option
This was a 15 passenger 2WD van owned by the USAF until 2010. I converted it to a camper for long-distance travel. My wife and traveled in it for 3 years, staying in it months at a time.
This van was set up for extended off-road, no RV Park travel that does not require a hose to fill up with fresh water or dump. Fresh water is stored in a 6-gal jug that feeds the pump. Gray water is collected under the sink in a 1.5 gal container. This is a minimalist rig, but quite comfortable if you like to travel and camp without luxuries.
We don't need 4WD any longer, so it's on the market. It runs and drives fine.
The truck:
2003 Ford E350
139k miles
5.4L gas engine
3 spd auto transmission w/OD
3.55:1 rear gears
Leaf suspension
2" receiver hitches front and rear
Brake controller
AM/FM/CD/USB Stereo can take a plug-in camera
Alarm with remote start
Power windows and locks
12V outlet with a 3-plug expander
Driving and fog lights
Backup flood light
K&N Cold Air Intake
Passenger seat swivels 180 deg.
Air horn
Bed liner covers the roof
14-15 mpg on highway
Very dark tint on all windows behind the seats
Seats and sleeps 2
Storage deck on rear roof
4WD conversion:
4X4 conversion by Out of Bounds
Dana 44 straight axle
Leaf suspension
Warn manual hubs
NV271 Transfer case, manual shift
3.55 gears
Approx. 4" lift from original
Living quarters:
2 twin beds 74" x 24" with custom futons
Under-bed storage
Behind-bed storage
Velcro-attached screens on driver, passenger, and rear doors
Galley sink with 12V demand pump
Galley storage
Barn door storage
LED lighting
Window covers
AC is set up for solar addition
30 Amp shore power runs 4 ac plugs on two circuits
Insulated walls
Fantastic fan vent
Solar System Option -- You install
Includes:
215 Kyocera Watt Solar Panel
12V 1000W Inverter
DC (solar) breakers and breaker box
MPPT solar controller
Remote meters for controller and inverter (the hole in the back door of the van is for the inverter meter
150 Amp fuse
2x 6V Golf Cart batteries
30 Amp transfer switch
Cabling
Everything is located in Carson City, Nevada.
$14,000 firm for the rig without the solar system
$1300 for the solar system
kenstrandberg is offline   Reply With Quote
Yeti
ACTNPKRYETI
PigPen
velo47
