Old 02-01-2015, 07:04 PM   #1
JJSporty's Avatar
Sold - 2006 Ford E250 5.4L V-8
More Photos in Galley
Vehicle Chassis
• 2006 Ford E250 RB 5.4 V8
• Vehicle Height – 83” to Top of Roof and 85” to Top of Awning Housing
• Oxford White with Clear Coat (van kept covered and waxed twice a year)
• 54,000 Miles (well-maintained with oil and filter changed every 3,000 miles)
• 14 MPG (average over 30,000 mostly highway miles)
• 35 Gallon Gas Tank
• Automatic Transmission with Overdrive
• Limited Slip Differential
• 4 Wheel ABS Disc Brakes
• Michelin LTX 245/75/R16 MS2 Tires (New – 3/27/14 @ 44,667 miles – excellent tires for this vehicle)
• Polished Aluminum Wheels
• Chrome Bumpers Front and Rear
• Halogen Head Lamps
• 2” Factory Receiver Hitch with Electrical Wiring
• Engine Battery (New – 7/12/14 @ 41,589 miles Group 65)
• Factory Air Conditioning
• Power Windows, Locks, Side Mirrors
• Tilt Steering Wheel/Speed Control
• Factory In-Dash Clock/AM/FM/CD Player with Front, Rear, Side Door Speakers
• 4 Cup Holders and Lower Storage Bin in Cab Area
Sportsmobile Equipment
• Seats 5
• Sleeps 4
• Front Driver and Passenger Captains Seats Swivel 180 Degrees
• Modified Sportsmobile RB-30 Floor Plan – Walk Through Front to Back
• Penthouse Top (extends to windshield – storage shelf above cab with top up) Manual
• 5 Penthouse Windows all with Screens, 4 with zippered Clear Vinyl Windows and Roll-Down Shades
• One-Piece Penthouse Bed (40” X 68”)
• “Goucho” Couch Converts Into bed 44” X 68” + 9” Extension = 77”
• Dove Grey Cabinets
• 5 Storage Cabinets, 4 Drawers, 1 Full-Height Pull-Out Pantry, 2 Over-Counter Storage Bins, 1 Flip-Up Counter Extension, and 1 Flip-Up Gaucho Side-Table
• Magazine and Map Holder
• 3 Retractable Hooks
• Under-Floor Storage in Rear
• Drop-Down Task Tables and Storage Compartments in 2 Side and 1 Rear Door
• Overhead Storage in Cab Area
• 2 Illuminated Vanity Mirrors on Sun Visors in Cab Area
• 2 Large Storage Pockets on Back of Front Seats
• 1 Storage Pocket on Rear Door
• Electric Flush Porta-Potti
• 3 Sliding Windows with Screens and Day/Night Shades
• All Rear Factory and Sportsmobile Installed Lower Windows Tinted
• Front, Side, and Rear Privacy Curtains (Reflectix interior window panels cut to size for windshield, cab, and back windows for hot/cold weather use)
• Exterior Vinyl Cab/Windshield Cover for interior sun protection (New – used once)
• Rear StarCool Air Conditioner with Thermostat
• Microwave Oven Dometic 700 Watt .7 Cubic Foot
• 2 Way 12 Volt DC/120 Volt AC Norcold 3CF Refrigerator
• 2,000 Watt Inverter/Converter/Charger with Remote Monitoring Panel
• 2 Lifeline Group 27 100 Amp-Hour AGM Batteries (New – 7/11/14 @ 41,589 miles)
• 120 Volt AC 30 Amp Electrical System with GFI Protection
• Indoor/Outdoor Digital Thermometer
• 120 Volt AC 2.5 Gallon Water Heater
• 10 Gallon Fresh Water Tank with 12 Volt Shurflo Water Pump
• Stainless Steel Sink with 8.5 Gallon Grey Water Holding Tank
• 12 Volt 2 Speed Oscillating Air Circulation Fan
• 3 12 Volt High/Low LED Lights
• 3 12 Volt LED Reading Lights
• 1 12 Volt Florescent Task Light
• CO and Smoke Detectors
• Removable Dining Table with High and Low Pedestals and tripod base
• Matching Grey Upholstery Throughout
• All Cables and Hoses to Connect to Shore Water, Power, and Cable TV
• TV/DVD/CD Player 12 Volt Coby TF-1570 15” on Articulating Tilt and Swivel Arm with Tie-Down Strap
• Cable TV Exterior Hook Up and Interior Wiring In-place
• Rear Radio Power Selector Switch
• Exterior 120 Volt Outlet
• Exterior 12 Volt LED Porch Light
• Door Talon (to hold rear side door open when parked on a slope)
• Fire Extinguisher
• All Electric Sportsmobile Conversion (no propane tank or propane appliances)
Additional Equipment
• 72” Thule Roof Rails
• Thule Rooftop Carrier Bars with Locks
• Rear Door Mounted Ladder
• Rear Door Spare Tire Mount with Full Size Never Used Spare Tire and Cover
• 8’X10’ Fiamma Awning (Added 2010)
• Fitted Fabric Van Cover (New – replacement) after 5+ years)
• Custom Locking Receiver Hitch Carrier for Honda 2000 Watt Portable Inverter/Generator
• 2000 Watt Honda Inverter/Generator with Cover
• 120 Watt Portable Zamp Solar Panels with Case and Exterior Zamp Connection Port
• Custom Straps for Securing Cargo Throughout
• Full All-Weather Rubber Backed Fitted Carpet to Protect Marine Vinyl Floor
• Carr Super Hoops Driver, Passenger, and Side Door Hoop Steps
Jeff and Janna
2014 Brilliant Silver MB Sprinter 3.0L V-6 High-Top 144 WB Modified RB-153S Espar D-5 SC Hydronic 200W Zamp Solar
SOLD 2006 White Ford E250 5.4L V8 4X2 RB-31 Modified, PH Full Length Garageable
JJSporty is offline   Reply With Quote
Old 02-01-2015, 07:55 PM   #2
Re: 2006 Ford E250 5.4L V-8 $39,950 54,000 Miles
Sorry to hear you guys are selling! Good luck.
Old 02-07-2015, 02:43 PM   #3
Nice Van.
Saw it has a roof rack. Does it have the power pop up?
Sent you a pm.
gbail is offline   Reply With Quote
Old 02-07-2015, 09:40 PM   #4
JJSporty's Avatar
It is a manual Pent House Pop Top - not electric. The roof has the rails in place and the actual racks will be included in the sale.
Jeff and Janna
Old 02-08-2015, 02:26 PM   #5
JJSporty's Avatar
Shore power or campground hook-ups are required to power the 2 1/2 gallon 120V electric water heater which is located in the cabinet below the sink, to run the microwave oven, and to use the StarCool air condioner.
There is NO onboard propane tank installed so NO built-in furnace or stove.
Jeff & Janna
Jeff and Janna
Old 02-08-2015, 04:48 PM   #6
But the Honda genny can be used to run the Starcool, water heater, etc., right?
Old 02-08-2015, 06:39 PM   #7
JJSporty's Avatar
The generator will charge the batteries. The water heater and the StarCool are both huge battery drainers so expect to have to run the generator a significant time to replenish.
Jeff & Janna
Jeff and Janna
Old 02-08-2015, 09:06 PM   #8
Could you add a few interior photos?
InigoMontoya is offline   Reply With Quote
Old 02-08-2015, 10:57 PM   #9
mikracer's Avatar
Great looking van! I noticed that the penthouse top goes all the way up to the front windshield. Did you special order it this way? There has been some mention where people wished SMB offered this, but this is the first factory installed top that I've seen that goes to all the way up to the front. Are the latches on the exterior to hold the top down? Also, what do you use the extra space above the cab for? Storage when the top is up?
Old 02-08-2015, 11:30 PM   #10
gcvt's Avatar
^^^This!
Greg
New van: 2003 E250 EB10
