Old 11-03-2015, 10:09 AM   #1
Help! Need help with a Trace inverter - remote switch
Need help with a Trace inverter remote reset switch... Mine was stolen then recovered and the remote reset switch cable is torn out and I don't know the wiring pattern... If anyone has a van from the late 90's that I could look at that would be great! Thanks in advance - Rob in SLC, Utah
Dummyfatpigpoo is offline   Reply With Quote
Old 11-03-2015, 10:42 AM   #2
Re: Help! Need help with a Trace inverter - remote switch
Which Trace inverter, the M1512? That's what I have, unfortunately I am out of town till Thursday night. If you don't have a response by then I will post up some pics.
Old 11-06-2015, 09:20 AM   #3
Ok so here is the Inverter that I have Trace M1512:
And here is the RC(Remote Control switch that I have)
Here are a few pics of the pins:
Here are the Pinouts as I could see them. The orientation is such that the 2 empty pins are at the top of the switch towards the light and as if you are holding the switch with the pins facing you. The "bridge" is simply a short bare wire soldered between the 2 pins.
Old 11-06-2015, 11:05 AM   #4
I have the same inverter and had the same switch (98 SMB). I too, accidentally pulled the wires off the switch somehow and could never figure out where to reattach them. I gave up and installed a remote panel that I got off Ebay (forget the model number), which is much more useful than the basic on/off switch.
Old 11-06-2015, 11:07 AM   #5
BTW, I have the manual for this inverter sitting around scanned somewhere if anyone needs it.
AWOL
Twoxentrix
Malbec
brushogger
