An online forum community for the owners, admirers and fans of Sportsmobile vans and Sprinters, new and old. Share photos, advice, discuss modifications, camping or buy & sell. Anyone who owns, has a passion for, or just curiosity about SMBs, come in!
Please do not use this section, or any part of this site to publicly post or request information for the purposes of copying any manufacturers’ designs for the purpose of duplication.
You may post publicly photos and information for purposes of improving, comparison, issue resolution, or repair, you may also privately pursue such information- however blatant requests for and public posting of images and specifications for the express purpose of reproduction or deconstruction will not be tolerated and will result in warnings or suspension from the forum.
Joined: Sat Jul 28, 2007 8:41 pm Posts: 29 Location: Sacramento Ca area
Posted: Thu Jun 05, 2008 5:01 pm
Post subject: Home built 2007 Ford E150 van with Sportsmobile top
I have now completed construction of my homebuilt 2007 Ford E150 Econoline Van with Sportsmobile Top.
See "Yahoo Groups" / "sportsmobile_owners" group / "Files" / "Terry's 2007 Ford Construction" folder /
"Terry's Ford Narative" file for details of construction.
See "Yahoo Groups" / "sportsmobile_owners" Group / "Photos" / "Terry's 2007 Ford Construction Photos"
for, of course, construction photos.
Posted: Mon Jun 09, 2008 8:29 am
Post subject: Terry's 2007 Ford van construction description & photos
Terry's 2007 Ford E150 Econoline van with Sportsmobile top
I bought the 2007 Ford van new, in late 2007 with the following Factory Options installed: 4.6 L V8 Trailer Tow Package Power Door Locks Power windows Remote Key less entry Cruise control power mirrors
I selected the Ford van over Chevrolet because of the much cheaper cost of the this Ford van.
I selected the Sportsmobile top over the GTRV top primarily because of build scheduling. I went to Sportsmobile Texas instead of Sportsmobile Fresno because, Sportsmobile Texas would install a garagable top on the van, and Sportsmobile Fresno would not. After I negotiated a early date with Sportsmobile Texas, it only took Sportsmobile Texas a day and a half to install the top. Normally it takes a day, but, because I was getting a low profile powered top, it took more time.
See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "Ford Van Parts List.PDF" file for A list of Parts that I purchased.
As is indicated in "Ford Van Parts List.PDF" file, I purchased several parts from Sportsmobile as follows:
door catches, hinges, battery rack, inlet power cord & connectors, Penthouse bed, hoop steps, and, of course, garagable "powered" top.
Note - I did not install a propane system, nor a furnace, nor a cook top in this van. I have found that I do not cook inside. I use a portable 1 burner stove for heating water. I have, previously had propane furnaces; but, I have never used them in the van. I do have a portable electric heater. Without any propane appliances, I had no need for a propane system.
A list of tools that I used in converting the van is as follows: Circular saw, table saw, saber saw, belt sander, in line sander, "Kreg" pocket hole jig, electrical drill, screw driver bits, Forsner bits, various clamps, soldering gun, 48" guide for cutting plywood, 4 metal saw horses, and 4' x 8' x 1/2" press board used as a layout table.
I started work on the van, in earnest, in early February 2008, right after I got home from Texas. I did do a little work before the trip. I finished the conversion in late May 2008.
The first things that I did was remove the back and side door thrush holds in the van.
I then removed the jack mounting hardware.
I made a pattern/template out of heavy paper for the plywood sub-floor and the vinyl floor.
I then cut the 15/32" plywood flooring using the pattern/template.
I installed a 100 Amp circuit breaker under the hood wired to the chassis battery.
I then brought the other end of the electrical wire to inside the van at the gas fill area.
Sportsmobile installed Penthouse top, and temporarily connected power from powered roof control switch to electrical wire at inside gas fill area. This allows me to raise and lower the top during construction.
I then planned the wiring. See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "FORDWIR.PDF" file for the wiring schematic.
I then installed the step hoops.
I then installed the 15/32" plywood sub-floor.
I attached the plywood to the van sheet metal floor using construction adhesive and approximately 250 1" x #6 flathead sheet metal screws.
Cut Vinyl flooring.
Design interior layout. See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "FLORDING6.PDF"
Make patterns for side walls.
Cut out driver's and passenger's side 3/32" Oak plywood walls.
I painted all Oak paneling and plywood with Verathane Satin.
Install foam & fiberglass insulation.
Install all walls.
Make patterns for rear side & rear wall panels.
cut out, paint, & Install rear side & rear panels.
wire roof wiring for 110ACV, 12 DCV, from drivers side to passenger side. wire rear light to passenger side.
Install vinyl flooring. I used double sided tape at front back door and side door.
Make pattern for bench seats.
I used the "Kreg" pocket hole jig and screws for fastening all bench seats, cabinets, and doors.
In addition, I used wood glue for all joints.
Build bench seats. I used 15/32" Oak plywood for sides.
Install bench seats.
Install outside 110ACV input.
Install converter.
Install battery separator on drivers side, under bench.
Design drivers-side rear, front, and middle cabinets. See “Yahoo Groups” / “Sportsmobile_owners” group / "ACREF2.PDF" , "MIDCAB.PDF" , AND "POTTI3.PDF" for drawings of these cabinets.
I then made a template/pattern for cabinet sidewalls.
I then made the 15/32" Oak plywood cabinet sidewalls.
Make the three drivers side cabinets.
Install the three cabinets.
Make template, cut out & install passenger side mount for battery meter, 12dcv receptacle, 110 ACV receptacle, & pump switch.
Install 110acv receptacle & 12 dcv receptacle in drivers side bench. Install 110acv receptacle in passenger side bench.
Wire drivers side AC inlet, 110acv receptacle, DCV receptacle, front light, converter, battery separator.
Wire passenger side AC receptacle, DCV receptacle, light, trimetric meter, water pump.
Make cabinet doors.
Another technique that I have used to finish edges of the Oak plywood is to use a very thin veneer oak with glue on one side.
This looks better than the 1/2" x 1/2" oak edging that I used on this van.
install drivers side cabinet doors.
Install floor pedestal plate.
Mount battery rack.
Install 4D AGM battery.
Complete passenger side electrical.
Install "Danhard" Air Conditioning Condenser.
Build table & additional plywood to make up bed.
Design Passenger side cabinet. See "Yahoo Groups" / "sportsmobile_owners" Group / "Files" / "Terry's 2007 Ford Construction" folder / "SINK1.PDF" file
Build Passenger side cabinet.
Install Formica on cabinet, table top, and additional plywood to make up bed.
Install water system.
See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "WATER.PDF" file for drawing of plumbing connections to tanks.
Posted: Mon Jun 09, 2008 4:40 pm
Post subject: My 2007 Ford van hone built RV conversion
I added $15,000 cost in parts and tools for converting my van. This includes sales tax. The 2007 Ford van cost $19,800. A new RB12 costs $17470. Penthouse bed is $398. Danhard A/C is $2335. Porta Potti is $125. Powered low profile Penthouse top is $6500. There would be a $900 credit for no propane nor stove. The total is $25,928 plus $1880 tax for the RV conversion. Total is $27808. It looks like I saved around $13,000.on the conversion. However, I do not have as much standard equipment as Sportsmobile.
Joined: Fri Oct 12, 2007 7:13 am Posts: 281 Location: Chicagoland
Posted: Tue Jun 10, 2008 8:13 am
Post subject: Re: My 2007 Ford van hone built RV conversion
Thanks for the details.
One last Q: How many hours do you think it took?
Also, I would say you saved about $8000 buy using a 2007 van.
Congratulations on the build, it looks great...certainly takes a lot of passion and sweat.
I do not know how much the van weighs.
___________________ Thanks, Marty
Marty's 'BearsMobile'
Joined: Thu Jan 31, 2008 3:25 pm Posts: 897 Location: Baja Whenever Possible
Posted: Thu Jun 12, 2008 9:17 am
Post subject:
Impressive build thread. Thanks for posting. Very nice work, by the way. I originally thought about a home brew Sportsmobile, but quickly decided I just don't have the time (marriage is strained enough with buggy mods, motorcycle trailer building and old VW resto project). A home brew SMB would have cost me more in divorce attorney fees, so it just didn't pencil out. Congrats again. You've got a nice well-built ride.
___________________ It takes a village to raise an idiot. You must live in a big city.
Joined: Tue Jul 08, 2008 7:44 am Posts: 119 Location: Fruit Heights, Utah
Posted: Wed Jun 03, 2009 9:39 pm
Post subject: Re: Home built 2007 Ford E150 van with Sportsmobile top
Good job, I'll be starting ours in a little over a week, were really excited to get started (on the interior) so we can be finished & using our creation! Keep the pic's coming and your parts list (If you don't mind). Enjoy
___________________ Cheers, Jamie 2006 E350 Quigley 4x4, building the conversion with the gracious help from the people on this awesome forum! I'll try & post all of our progress on our family dream, when we have some.....
Users browsing this forum: No registered users and 0 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
