An online forum community for the owners, admirers and fans of Sportsmobile vans and Sprinters, new and old. Share photos, advice, discuss modifications, camping or buy & sell. Anyone who owns, has a passion for, or just curiosity about SMBs, come in!
This section is for project write up, identification of known issues, and their resolutions. This is not for asking questions, discussion of possible solutions, or anything other than "complete" subjects. [more]
Posted: Sun Oct 21, 2007 1:33 pm
Post subject: Dynamatting the Fridge and Rebuilding the Wall
Project Overview: Well the fridge has always been loud and rattled the counter tops, drawers and the whole van. Based on input from the group and Badgertrek.com I pulled the fridge to determine the problem and found that not only was it rubbing on a bolt, but the wall construction behind the fridge was pretty shoddy and did little to cover the gap to the outside.
I also took a crack at addressing the efficiency of the fridge simply through disabling the 110 outlet when not attached to shore power.
Pulling the Fridge Basically there are two screws on either side holding the fridge in. To get to them you have to remove the door, then some hardware, the lower panel, slide and twist off the molding and then after the screws pull the fridge out. Unplug the 110 connection (be careful not to rip out the wall) and disconnect the 12v wires at the clips.
Ready to rock and roll
Pull back the carpet
Hmmm, I know this comes out…
Gently Pull Bottom
Remove door screws
Remove door screws
Remove plastic Ls
Start at the bottom and pull out the outside
Slide down (to get out of the top molding)
The outside is easier to roll off despite being a solid tab.
Remove 4 screws
Gently pull out
There are DC and 110 connections
The DC is a plug, the 110 has male-female clips. Be careful not to rip the wall when pulling out the 110 plug- that part of my wall was just loose over the gap.
Addressing the Vibration The vibration came from the L bracket on the panel behind the driver's seat being installed too close. The solution was to cut a channel in the L bracket and reposition that part of the wall further out.
The bolt is just held on by a nut and cut washer. Removing and reinstalling is easier with two people, but if you drop a box wrench on the bolt you can work the nut alone (depending on your space with your configuration).
I was a little disappointed that the installer just forced the fridge in, as is clear from the dents, instead of addressing the problem. But with the state of the wall, and the "out of site out of mind" mentality they both reflect, I'm not surprised.
A tooth rattling vibration you say? Ah, there's your problem mister.
Note the dent where the space was obviously too tight and the unit was forced.
Well, don't look at me
The culprit has a flattened cap from years of vibration.
The nut on the lower bolt of the L is in there (better pic later).
Nut and washer removed
Bolt and hole without the L
Since I don't have the equipment to wallow out the hole I decided the best way to reposition was to make a slot.
Parts for reinstall
Location of nut
Washer and nut- would it have killed them to use a tabbed nut?
Relocated and tightened down
Rebuilding the Wall and Rewiring the Socket Based on discussions here, RV.net and the Norcold manufacturer's website, I found the fridge runs on 110 whenever it is supplied. There are two reasons this is bad. The first is that according to some posts 110 has a more frequent duty cycle using more energy to achieve the same results.
The other is that the fridge will run on 110 whenever it is supplied, and 12v only when 110 is not available. What this means is that whenever I was turning on my invertor, the fridge was switching to 110, and not only using more power from the worse duty cycle, but taking 12v through the invertor and converting it to 110 to use. Simply leaving the invertor on overnight can put a huge hit on your batteries this way.
So, while rebuilding the wall and addressing the gaps I also installed a Wirecon switch to control only the refrigerator outlet. This switch will be off at all times unless I'm plugged into shore power, in which case I want the fridge running on 110.
By rights I should have pulled the gray water tank and done the full gap with Great Stuff but I decided to do my best without taking more of the counter apart and tried to just get it everywhere. If the extreme amount of road dirt inside the cab wasn't enough proof, putting a small fan near the hole was. Between the Great Stuff inside and outside and the new wall I hope this has been addressed enough to reduce the problems.
The sockets are Wirecon WDR style. Two screws with tabs.
Some "Great Stuff" for the gaps, wire and a switch for the project.
The switch is by Wirecon also and has a similar install.
A dry erase piece of wainscoting courtesy of Lowes.
Excuse me there seems to be a board in my spot
Great Stuff applied outside
5 minutes later
about 15 minutes
about 1/2 hour
Great Stuff on the inside too
Expanded and Cured
Cardboard template
Easy to change
Measure never, cut lots
My ultra hi-tech working area
No wonder the cuts aren't straight
I left some space at the top to recut when I have a table saw again. I'll probably add some silicone when it's cleaned up too.
Moving up to the socket behind the driver's seat
Cut hole below for switch
Switch wired behind driver's seat for testing
And fully installed
Reinstalling I can't begin to tell you how easy the Dynamat was to work with. I doubled up on nitrile gloves and used the mini wooden roller I purchased with the kit. I cut the pieces over cardboard with a box cutter and they applied easily. Admittedly I was working with relatively square flat surfaces, but the mess and the fuss was totally minimum.
The result of the whole project isn't really the silent fridge I hoped for, but the tone is much bassier and easier to live with. You can still feel the vibration in the counter, but it's not the "rattle everything to death" vibration it was.
Dynamatted fridge ready to go
Everything realigned but there was a gap under this foot, so a piece of the wallboard went to use.
Molding back on
The previous owner's insulation
Scribbles and I agree it's better but not perfect.
Joined: Mon Jun 18, 2007 9:28 am Posts: 598 Location: Helena, Montana
Posted: Sun Oct 21, 2007 7:37 pm
Post subject: Refrig and Dynamat
Great documentary jage! I was out soloing for several nights on Vancouver Island two weeks ago and began to notice a lot more noise on start up of my 2.7 cubic foot frig cycle. i moved stuff around in the frig but the start up noise was coming from the fan and compressor. I will have to pull it sometime this winter and try to quiet it down.
Could you repeat the process with a labradog instead of the cat?
___________________ 2006 Baja Tan SMB 4X4 EB50 PH 6LPSD Mohawk Royalex Solo 14 foot canoe (light white-water) Mad River Kevlar Explorer 17 foot canoe (flat water) Dagger Royalex Legend 16 foot canoe (white-water) Maravia New Wave 13.5 foot raft (fishing and white-water)
Joined: Mon Apr 30, 2007 2:00 am Posts: 205 Location: New "Yawk" City
Posted: Tue Oct 23, 2007 9:47 am
That's the best SMB project write up I've seen.
Over the last couple of years, I've noticed my fridge is starting to make more noise and rattles sometimes. It was ultra quiet when new (4 CF.) Maybe it's time to do the fridge mod.
Does the fridge really run off the inverter when the inverter is turned on? I simply assumed the fridge 110V line didn't go through the inverter. I have my inverter on most of the time for the computer!
I'm going to have to check out my 110V circuit breakers now.
-Joey
___________________ 2005 Ford E-350 Diesel Sportsmobile
EB 102 Voyager top, 3.55 rear, Mobil 1 all around
X-Monitor with pyro, trans temp, boost + Scan Gauge
and now SCT Live Wire (Economy)
Joined: Fri Oct 12, 2007 7:13 am Posts: 281 Location: Chicagoland
Posted: Fri Oct 26, 2007 1:40 pm
Post subject:
Jage,
Thank you for the great write up.
I had a similar noise issue on my SMB. There was a terrible chatter noise from under the stove. I pulled out the drawers and saw the copper gas line was routed such that is rubbed on the cabinet walls.
- Root cause was the cutout for the gas line was not used...like your problem, the installer ignored the issue altogether and pushed the cabinet against the line.
- I dynamated portions of the cabinet and placed some on the area in interferance. Much much better.
If I order a new SMB, I think I'll skip the stove/furnace. I like the a stove that I can remove and cook outside. There is not enough room inside and I like to grill too. An electric blanket is a great subtitute for the furnace.
___________________ Thanks, Marty
Marty's 'BearsMobile'
Joined: Thu May 17, 2007 10:17 am Posts: 1597 Location: California - Santa Clara
Posted: Fri Oct 26, 2007 5:45 pm
Post subject:
I was really excited by the project title, until I noticed it really didn't say 'DYNAMITED the fridge'.
Man, I thought you must have gotten really ticked at it!! And I understood why you had to rebuild the wall.
I'm about ready to pull my fridge and add some styrofoam insulation to reduce running times. I think I have to pull the doors off the cabinets across the way to get enough room to pull it out.
___________________ 04 EB350 Modified EB14 Floorplan 6.0 PSD 4.10 Posi SMB Trailer Salem Kroger coil spring 4wd 140A Alternator 125W Solar panel Warn front bumper Coolant Filter 275/70-18 (33") tires on 05 F350 wheels 75,627 miles 16.49 mpg average Alaska to Key West and more
The fridge as previously noted is much much bassier with the Dynamat. The vibration is still transmitted to the counter but it's muted, and the direct contact between the fridge and bracked eliminated most of it.
I'm careful not to leave anything on the counter that could rattle before going to bed, otherwise the only thing that rattles is the counter itself. I'm kicking myself but when I had the fridge out the screws seemed tight so I didn't think the counter needed to be snugged.
When I get around to redoing it I think the counter to walls above the fridge is a great place for some material to dampen sound and vibration. I'm pretty sure the screws back out over time and the real source is the counter vibrating against the walls and brackets. Even a little bead of caulk during construction would alleviate this without making the counter hard to remove.
As far as cold, the fridge is now working on 3 for general use. The frozen stuff is not really frozen though, so I think 3.5 or higher might be in order. Of course it's also no longer the Arizona summer so that needs to be taken into consideration.
I think in general the Dyanmat didn't noticably improve the cooling setting. I guess the duty cycle is less frequent, but again that could be summer vs. winter.
Does any know how to pull out the Norcold 3.0 fridge? I've been looking at Jage"s pictures which I'm guessing is of a 4.0. I've been messing with mine for 2 hours and still don't have the door off.
Users browsing this forum: No registered users and 0 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
