Closed Thread
Old 11-24-2008, 01:38 PM   #1
FAQ,s - Battery problems and common power calculators
Links to DC problems and related information
Choose the correct link for your problem:
BATTERY PROBLEMS:
Batteries going dead:
viewtopic.php?t=950
House battery dies quickly:
viewtopic.php?t=1833
House batteries keep going dead:
viewtopic.php?t=2080
Something is pulling down the house battery:
viewtopic.php?t=287
Starting battery voltage drops at start (starting batteries are shot in 6 months):
viewtopic.php?f=14&t=2410
Battery dies quickly (Voltage and % table):
viewtopic.php?t=1245
Charging problems:
viewtopic.php?t=1275
No apparent charge to house battery while driving:
viewtopic.php?f=14&t=2293
Battery voltage jumps up and down (clicking noise):
viewtopic.php?f=14&t=2079
Battery disconnect switch problems with solar (clicking sounds)
viewtopic.php?f=14&t=2478
Sure Power separator over heating:
http://www.cooperindustries.com/content ... fo_NA.html
Sure Power battery separator:
http://www.texasindustrialelectric.com/ ... 200_BP.pdf
Blue Sea separators:
http://www.waytekwire.com/datasheet/780 ... ctions.pdf
Blue Sea 7622 separator:
https://www.bluesea.com/products/7622/M ... 2V_DC_500A
SMB switching from SurePower to Blue Sea
Other related DC issues:
Tripp Lite inverter/charger dip switch settings:
viewtopic.php?f=14&t=6444
How long a house battery will last:
viewtopic.php?t=2074
How will fluorescent lights affect my house battery system?
viewtopic.php?f=14&t=2248
1 or 2 batteries and what size:
viewtopic.php?t=1761
Running a twin battery system (worth it?):
viewtopic.php?t=1301
How many amp hours are needed (how many house batteries):
viewtopic.php?t=2107
How many batteries needed for a new order and solar questions:
viewtopic.php?t=1600
Using multiple types of batteries and charging:
viewtopic.php?t=1737
Adding a house battery:
viewtopic.php?t=1831
Alternative to stock batteries:
viewtopic.php?t=1956
Replacing OME starting batteries with Optima batteries:
viewtopic.php?t=2162
Thermoil batteries:
viewtopic.php?t=1756
Access to house battery on a 2001 EB-51
viewtopic.php?t=1755
Mounting batteries inside the cab:
viewtopic.php?t=1628
Inside mounted house batteries and inverters:
viewtopic.php?f=14&t=2400
Starting batteries (how are they connected?)
viewtopic.php?t=1917
Access to house battery terminals:
viewtopic.php?t=2085
Question on storing an SMB:
viewtopic.php?t=983
Equalizing a battery:
viewtopic.php?t=1898
No access to shore power:
viewtopic.php?t=2086
Charging a portable battery:
viewtopic.php?t=1517
12V plugs work off what battery:
viewtopic.php?t=1535
Charging methods:
viewtopic.php?t=1511
NiMH batteries:
viewtopic.php?t=1441
Mounting a house battery:
viewtopic.php?t=1332
Will a battery tender or trickle charger affect the house battery system?
viewtopic.php?f=14&t=2286
Specific charging systems:
viewtopic.php?t=881
Information on a “Charge Wizard”:
viewtopic.php?f=14&t=2334
Xantrex charger/inverter problems:
viewtopic.php?t=735
Monitoring with a volt meter:
viewtopic.php?t=693
Voltage shutoff device link:
viewtopic.php?t=499
How to test a battery:
viewtopic.php?t=1180
Dropping the starting batteries on a 6.0 PSD:
viewtopic.php?t=231
6 Volt batteries:
Switching to a 6 volt system and why:
viewtopic.php?t=1548
6V verses 12V, mounting brackets and maintenance issues:
viewtopic.php?t=1625
Electrical Links:
Inverter Basics
Link to Northern Arizona Wind and Sun and AGM info
Understanding and Maintaining Your RV's 12v System
Link to proper battery box Hydrogen venting
DC usage Calculator
RV solar panel calculator
Wire loss/distance calculator
Battery Calculators, Generation Calculators, Solar Radiation Maps, Wire Calculators and other tools.
Battery group size chart and common battery dimensions
AWG wire size and amp limits chart
Blue Sea wire calculator
Battery tutorial
Basic RV electrical
daveb is offline
Closed Thread
