Old 10-18-2012, 04:49 PM   #1
Zeta's Avatar
Swingers
I was never happy with my Aluminess rear swing outs. They loosened over time, and finally the spare tire carrier failed.
I hoped to make it a simple bolt on procedure--didn't work out that way:
I made two 90 degree brackets that support the shafts Rock Slide engineering uses on their Jeep swing outs.
The brackets are made from extremely strong 2"x.250" steel square tubing, and bolt to the frame of the van and to the Aluminess bumper which, itself, is very rigid and well made.
I copied RSE's design for the swingouts. They are made from 2x4"x.120" steel tubing.
The video says it all:
http://youtu.be/ji8vCiviPXg
I'm very happy with the result. They have a much cleaner look than stock. Still need to make a few adjustments however--the EZ Rack on the right side will touch the taillight if not careful. And even though the rear doors have been reinforced with steel plate, they are still flexing too much for my taste. Gonna give them a bit of a test in the Maze next week!
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 10-18-2012, 06:11 PM   #2
Swingers
Bravo !
Old 10-18-2012, 06:21 PM   #3
Gnarvan's Avatar
Re: Swingers
How much weight do you think you have put on the van doors? Do you have any pictures of the steel plate reinforced doors? Where are the doors flexing? Will the flexing of the doors lead to cracks and door failure?
How do you access the lock on the back door? Does the spare tire swing completely out of the way? The one motion pull cord to open the swingarm and the door as one unit sure would be handy.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 10-18-2012, 06:41 PM   #4
Zeta's Avatar
Swingers
The bumpers carry all the weight, but the doors hold them closed.
I'm planning on building an internal frame for each door. It will span from the hinges to the latch, boxing in the structure.
I'll let you know next week if the doors cracked.
Z
'06 RB50 SMB Diesel
Old 10-22-2012, 11:19 PM   #5
Re: Swingers
WOW! That looks really clean. Can't wait to see those door reinforcement frames.
Nice work.
jwintersteller is offline   Reply With Quote
Old 10-23-2012, 11:13 AM   #6
geoffff's Avatar
Re: Swingers
So cool!
Taking notes...
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 10-23-2012, 03:38 PM   #7
Ultrasport12's Avatar
Re: Swingers
Wow you have done a really great job on those....
I really like the fact that you can just open the door and the outer parts move too...
If it wasn't solid enough or you are worried about the doors couldn't you have a pin, latch or something in the center of the bumper (or just lock it to the other side of the hinge out) that you could use while off roading or long trips but when you were camping and such you could just leave it out and just use the doors without the pin?
...Jamie
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 10-23-2012, 05:15 PM   #8
Re: Swingers
Look, that's really cool and all but not what I was expecting the pictures to show after seeing the title. I'm somewhat let down.
Old 10-27-2012, 09:55 AM   #9
Pntyrmvr's Avatar
Re: Swingers
Hi;
Zeta that is how the unit should have been made in the first place. A very slick design. Well done.
Regards,
Gavin
Old 10-27-2012, 11:40 AM   #10
Swingers
Look who I ran into at Bass Lake. Nice meeting you Zeta.
