Old 12-08-2015, 08:05 PM   #11
Seems low to me. I got new custom springs front and rear and new shocks and it was around $5k installed.
1998 E350 4x4 7.3l Club Wagon Chateau with SMB top
trquinn is offline   Reply With Quote
Old 12-08-2015, 08:06 PM   #12
UJOINT's Avatar
There are so many variables with a DeQuig..... That does sound a bit cheap. I couldn't/wouldn't do it for that! Don't put yourself in the same (or worse) situation.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 12-08-2015, 11:42 PM   #13
Pntyrmvr's Avatar
Hi,
My Advanced conversion from 1985 used rear blocks. Expect blocks as opposed to new leafs for that quote.
Regards,
Gavin
Old 12-09-2015, 08:06 AM   #14
alta825's Avatar
Coming from a recently DeQuiglified rig, keep saving up your $$ and do it right with a call to Chris. You will not regret it
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 12-09-2015, 08:44 AM   #15
MrHenrietta's Avatar
What are the implications of putting leaf springs on a Quigley conversion and lifting to 6 inches? What could go wrong?
2003 7.3 UJOINT 4x4 SMB
MrHenrietta is offline   Reply With Quote
Old 12-09-2015, 08:51 AM   #16
UJOINT's Avatar
Spring rates, shocks, steering & trac bar fitment/angles, how will the existing axle be converted to leaf, etc.
Every Advance conversion I've seen has F series take out springs and thats not the best way to improve the ride or handling.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 12-09-2015, 09:37 PM   #17
BajaSportsmobile's Avatar
What have you done to improve the ride of your existing Quigley setup?
AgileOffRoad.com
Old 12-09-2015, 09:57 PM   #18
All I've done is replaced worn out parts. Recent work includes:
-Front outer Axle U-Joints
-Left and right Front Outer Tie Rod End Replaced
-New brakes all around
-Sway Bar Bracket Bushings replaced
-Rebuild of rear differential
-New front drag link and stabilizer shock.
I've only ever had the death rattle while braking on steep hills around 40mph.. I haven't had it recently so I'm hoping it's fixed.. My goal in the deQuiglifcation is really just to safely get a 6 - 8 inch lift on the van while improving ride on and off road. I'm open to any and all suggestions.
Old 12-09-2015, 10:01 PM   #19
Why do you want 1 to 3 inches more lift?
What size tires are you running now and what do you want to run after the "lift".
AgileOffRoad.com
Old 12-09-2015, 10:32 PM   #20
32's. I really like the look of the bigger lift with 33's.
