Originally Posted by HIGHCOUNTRYMIKE
I just had the front end aligned (after hitting a rock, big rock which mis-aligned sterring from --- to / ) 2003 E350 EB 4X4 7.3 SMB
You might want to start a new thread, but that's really odd. Did the rock bend the tie rod?, did the shop straighten it? Is it bent again? Could the pitman arm be loose on the sector shaft? Is the steering box loose on the frame?
As for the OP's original issue, I had a bad rattle that took a long time to find, but it turned out a shock mounting hole was wallowed out and the mounting bolt was rattling around. It actually happened twice, once in the rear and once in the front.
