03-29-2020, 12:08 PM
Originally Posted by Farmbro
Thanks all, now that it stopped raining I have verified it is a semi-float unfortunately and so further thought required. Will investigate the Sterling axles and the full float Dana assembly which I may be able to pull from a wrecker locally to minimize the bill.
Presumably a full float from an ‘09 forward f350 should be a reasonably clean swap?
You will need a 2011 or newer F250 axle because of RSC. I don't think the F350 got RSC until 2014. Basically, make sure the new axle has outboard speed sensors and 2 brake hoses coming off the axle, rather than been teed into a single hose.
03-29-2020, 02:44 PM
Don't the 2013 and newer Sterlings have bigger brakes then the previous years?
03-29-2020, 06:16 PM
Yes. That's another good reason to go newer.
03-30-2020, 02:50 PM
So I found a full float Dana 70 out of a 2014 e350 with 4:10’s in it albeit not sure open or LSD but has the disc brakes already. Presumably a pretty straight upgrade albeit I suspect hub size will be bigger than 125 which is my current wheel set up? Width and spring perches etc should all line up?
03-30-2020, 03:02 PM
This will be a direct drop-in. Hub diameter is the same. But beware it's 5" wider, and you'll still need the wheel adapters to match your front bolt pattern. Also... make sure it's not from a dually. Sometimes the wrecking yards aren't so good with their descriptions or cataloging.
03-30-2020, 03:27 PM
Comes from a single they verified that and they gave me the VIN so will double check with the dealer. Trying to understand the RSC issues as it seems to have been a cut away vehicle originally and may or may not have been configured.
Width was one of those things I was working on next - 5 inches is huge - seems like zero offset rims needed instead of the negative 12 I have currently to pull the width back otherwise am well beyond my bushwhackers
03-30-2020, 07:16 PM
Based upon what I see here on the brake line junction this seems to be a 3 and not 4 circuit ABS so no RSC compatibility for my application - am I looking at it correctly?
03-30-2020, 08:21 PM
Can you get any more pics? The important piece to verify is that is has outboard wheel speed sensors, which will be poking through the brake backing plates.
03-30-2020, 10:13 PM
It sure I see much here beyond emergency brakes
03-31-2020, 08:36 AM
#20
Unfortunately whoever took those pics is smart-phone challenged.... it's too blurry to see any detail. All I can suggest at this point, is to verify the outboard speed sensors in person.
