Originally Posted by Lance
OK, I get the idea. I was thinking bump stops were a normal part of the package, not so?
Well.....they should be.....
There are 2 things that you need to achieve here....at a very high level....
1. The shock travel needs to exceed the axle travel .....at least a little bit
2. The installed length of the shock will be correct when the shock doesn't bottom out or top out at either end of the axle/suspension travel.
I had a similar issue on my van..I ended up going to longer shocks (needed more travel) and I had to fabricate a new lower shock mount that was about 3/4" lower. My top mount wasn't moveable.....
..also remember that bump stops will compress a bit when hit ......so shocks shouldn't bottom until the stops are compressed a little..it's a little fuzzy but take your best guess.
