Old 01-03-2021, 02:44 PM   #11
Originally Posted by Vanguy View Post
So is this an 8.8? Looks beerier than I remember one of those looking like.
This looks like a 9.75". I see a tag still on it? Maybe you can scrape off the paint and make it out?
Old 01-04-2021, 08:30 AM   #12
So then what would be my options for disc brakes on this rear end? The sellers says that it is a 9.75 with a 3.55 LSD. It is a 5 bolt axle.
Vanguy is offline   Reply With Quote
Old 01-05-2021, 05:35 AM   #13
Should I look for a 2004 - 2006 E150 with a 9.75 rear axle?
Old 01-05-2021, 05:57 AM   #14
Would it be possible to just put all the disc hardware on this axle housing? Was only wanting to swap out the whole axle assembly to get something a little stronger but looks like I already have that little something extra from what I thought I had.
Old 01-05-2021, 02:10 PM   #15
I think all of the 2000+ E150 axles are the 9.75” until the Dana go in ‘07. I don’t think a drum to disc conversion is really worth the trouble considering how easy an axle swap is.
Old 01-05-2021, 06:30 PM   #16
Would be nice to have the entire axle on a bench and go through everything including the brakes. Then just replace the whole shebang.
Old 01-05-2021, 06:35 PM   #17
From what I've been finding it looks like the 4.6 got the 8.8 and the 5.4 got the 9.75
Old 01-05-2021, 07:14 PM   #18
That would make sense. Brakes must be shared though. I didn’t see a brake parts breakdown by axle for those years.
Old 01-07-2021, 10:49 AM   #19
Vanzila's Avatar
So I just bought a 2000 E150 that has been 4x4 converted using a ujoint kit and a D44 front axle. I was wondering what kind of brake upgrade options are available? It would be really nice to it least do a rear disc conversion and possibly something up front as well. Would it be feasible to just upgrade the entire rear axle assembly with a newer 9.75 rear axle from a salvage yard?
Run the SSBC Kit.. you will be very happy. I am
https://ssbc-usa.com/collections/ford-big-brake-kits
Vanzila is offline   Reply With Quote
Old 01-07-2021, 09:03 PM   #20
moorefc's Avatar
If the purpose is stopping, rear brakes do not do much....If you convert to bigger rotors and calipers on the front, that would be an improvement...you can upsize providing your wheels accommodate it...In about 2008 the stock vans upsized the front brakes..Could also look at better rotors for the front as a way to nibble at it....
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
