Old 04-18-2024, 04:26 PM   #1
Catalytic Converter Quigley 4x4?
Hi, I have a 2006 ford e-350 6.8l v10. My catalytic converter was stolen and I am having trouble figuring out the correct one to order. Or even a straight pipe to order.
The stock on the 6.8l doesn't fit with the Quigley conversion. Drive shaft and gear box get in the way.
Any suggestions? Thanks!
Big B is offline   Reply With Quote
Old 04-18-2024, 06:13 PM   #2
IanF's Avatar
Did you try calling Quigley?
QUIGLEY MOTOR
COMPANY, INC.
100 Sunset Drive
Manchester, PA 17345
(800) 233-9358
1992 E350 7.3 IDI - "The White Whale" RV conversion planned.
IanF is offline   Reply With Quote
Old 04-19-2024, 03:40 AM   #3
marret's Avatar
Also, Quigley will provide a parts list for vans they convert.
Chris
Old 04-19-2024, 06:09 AM   #4
Why not just take it to your local muffler shop? Cheaper and simpler. There's nothing special about the exhaust except it's been rerouted.
I do suggest you take Marret's advice and get a Quigley parts list from them from your van if you don't already have it. Call them and ask for Kevin Wilcox.
Old 04-19-2024, 12:14 PM   #5
REDOVAL's Avatar
Depending where you are your options are limited at best. In CA, Magnaflow PN 4451300 is the only approved cat that can pass the BAR smog inspection. That PN is a universal unit but they have a direct fit one that will pass as well.
Scott
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 04-21-2024, 06:57 PM   #6
Big B -- be sure to let us know when/where you find a supplier for your CAT and maybe how much it set you back in $$ -
Old 04-22-2024, 09:38 AM   #7
deserteagle56's Avatar
Your 2006 came with only one cat?? My 2007 has four!
Worshipper of Wild Country
deserteagle56 is offline   Reply With Quote
Old 04-23-2024, 03:12 PM   #8
And my 2011 has only one. Weird, isn't it?
Old 04-23-2024, 05:40 PM   #9
My 2002 has one large main CAT and a smaller one off of each exhaust/manifold left and right !?
Old 04-24-2024, 03:49 PM   #10
Wow! Didn't realize there was such a variation in how many cats an Econoline might have. Mine has two smaller cats on each exhaust header for a total of 4.
Tags
2006 e350 4x4, catalytic converter, ford e350 van, quigley 4x4 conversion
