Originally Posted by h.grenade
There are other stupid things to consider also. Like I have curt front hitch that might be located in the same place that UJOR ties into the frame. That means if I want the front hitch back it would have to be on a bumper and I really don't want a giant front bumper right now. QuadVan can put a winch mounting plate right in the factory bumper.
I also wonder how strong the Aluminess/UJOR recovery points are. I don't see any info on their website about working load or failure point. If you have a 12k winch and do a double line pull that could put around 24k lbs of force. Well I guess its still putting 12k just with increased mechanical advantage. I'm still trying to figure this out. I doubt that those recovery points are going to stay on. I used a stuck force calculator and it could require almost 30k lbs of force to pull out when stuck in the mud up to the axles. A shovel is probably the best answer, 30k lbs is massive amount of force.
Anyway, just so many things to think about.
You’re right there’s a ton of variables to consider when building a van for your specific uses.
IMO, I’d have best 4x4 option for your needs, a higher priority than a front tow hitch. I’m sure there are front tow hitch's that will work for all conversions.
Also, There’s a member here ( I think it’s Saline) that confirmed that his Aluminess bumper is stronger than the ford mounts it bolts to. Using his front winch he broke a few ford welds on the bumper mounts. So those would need to be upgraded for maximum strength.
