Originally Posted by carringb
What year are you trying to swap hubs on? I’ve never heard of aluminum hubs on a heavy truck.
And why all this trouble to swap bolt patterns? A stock E450 has a 14.5K GVWR with 8x6.5 hubs. I swapped in an E450 axle and my rear axle weight often tops 12k on its own.
Its a 2004 Chinook E350 that i am converting to 4x4. I installed a 2005 Dana 60 dually front axle under it which utilizes a minimum of a 17" inch dually wheel to clear the calipers, those wheels happen to have 8x200mm lug pattern. The ford 4x4 dually pickups went to the 8x200mm lug pattern in 2005. The purpose is to avoid having to carry two spare tires with different lug patterns.
Single rear wheel vans can get away with running the 8x170mm lug pattern and swapping a sterling axle with that lug pattern or just running an adapter/spacer from 8x6.5 to 8x170mm so it matches the front lug pattern. Thats a no go on the Chinook even though i can have a set of 8x200mm adapter/spacers built, they wont make them any thinner than two inches.
Since my outer tire is already flush with the outside of the quarter panel they would be sticking out of the wheel opening the full 2" inches, then i would be looking at getting custom flares and mud flaps to prevent them from throwing rocks against the side of the fiberglass body.
Hope that helps, its a bit of a nightmare no matter how its approached. The dana 80 is just a dana70 with bigger guts. That said theoretically a guy should be able to swap hubs, rotors, caliper brackets, calipers from the dana80 onto the dana70HD. The question is... Where do your tires end up in relation to the leaf springs? The reason being.... as it sits right now in stock form there is only approximately 1/4" clearance between the back side of a 245/75-16 tire and the side of the leaf springs.
All of that leaves me with two options...
#1- spend a bunch of time and money experimenting with dana80/70 hubs and parts and possibly end up back at square one. In 2005 - 2006.5 ford used a bearing hub on the dually pickup trucks with larger bearings and races, then in 2006.5 and up they went back to smaller bearings and races that they used in the trucks 2004 and earlier. That said, there are different hubs, different bearings, different seals, different rotors, etc....
#2- fork out big bucks to have the custom hubs machined and be done with it.
