Originally Posted by TechTonics
.... Explain it to me like I’m a child.
I don’t even know if it has a locking differential. Agile did the conversion
With an "open" differential (the big pumpkin on each axle) only one wheel drives the vehicle down the road at any given moment for each axle.
A limited slip differential has clutches inside that allow the opposite wheel to help drive the vehicle if the driving wheel starts to slip/lose traction.
A differential with a "locker" feature allows the differential to have both wheels driving the vehicle when the locker is engaged. This feature is only used when off-road or other conditions where you need both wheels driving on one axle.
When you go around a corner the outer wheels have to spin more times than the inside wheels..since the arc they track is longer.....this is impossible with a locker engaged, so the tires make all kinds of slipping/skidding noises on dry pavement with a locker engaged.
If your van has a locking differential there would be another button for that, and the fact that it drives at least as good as your trooper (we used to have one of those) means the diffs are either open or limited slip, which is the most common setup.
Technically, with "open" differentials in 2WD the vehicle has one wheel pushing the vehicle down the road, and in 4WD you've got 2 wheels driving, one on each axle. Limited slip helps if the driving wheel starts to spin.
In my van my front diff is open and the rear is limited slip, pretty typical for these vans. There is an axle code on the Mfr data plate inside the driver's doorwell....if you post that here one of the smart forum members can tell you if the rear is LS. Your front is likely an open differential.
