Old 05-12-2022, 01:18 PM   #11
jeff.depaul's Avatar
FWIW, I was able to locate a 2016 E series dually axle (dana 80) - think it was from an RV and it fit perfectly on my 2010 E350 - no changes to shocks/springs or drive shaft, pretty much bolt-in. Even came with factory mount for the rear sway I added.
Mine came with 8x6.5" standard Eseries bolt pattern and dually wheels which was a bonus so I don't have different lug patterns and can carry a single spare. My sensor is not on the axle so no issues there either and even had the same rear brake line drop as my E350 (which I've replaced).
Finding dually fenders for an Eseries is only the real hangup, not able to find a reliable source anywhere.
jeff.depaul is offline   Reply With Quote
Old 05-12-2022, 06:47 PM   #12
Did you try these guys?
https://duallyfendersfiberglasstruck.com/
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Old 05-12-2022, 07:23 PM   #13
What year is your van? What year Dana 80 did you use? Did you have to relocate the leaf spring perches on the axle tubes? I would assume your van is pre 2005?
ScrapIron is offline   Reply With Quote
Old 05-13-2022, 09:11 AM   #14
He stated the axle in his post. 2016 E series RV. I assume class C. Van is 2010 E series. Amazing it crossed over. I thought earlier series had one center ABS signal as opposed to dual signal on 2015 and up.
Old 05-13-2022, 09:36 AM   #15
I must been half asleep. That doesnt really help me because all of the vans still use 8x6.5 lug pattern and i need an axle that utilizes the 8x200mm lug pattern.
Old 05-13-2022, 11:05 AM   #16
Can anyone give the year if in fact the ABS went from single center to dual outer ABS? Not sure maybe I am confused with the sterling axles??
Old 05-17-2022, 07:51 AM   #17
Originally Posted by Lilnuts2 View Post
Yes, they initially replied months ago but have been completely unresponsive since then. I would definitely not recommend them at this point.
Old 05-17-2022, 10:49 AM   #18
Orv
N8SRE
Old 05-17-2022, 01:59 PM   #19
Twoxentrix's Avatar
Originally Posted by Orv View Post
That just....awful - although functional, I just can't picture anyone doing this without also occupying the front passenger seat with a yellow rubber duck life-preserver.
Turtle
rafeman
ClifFord
EliMakes
