Originally Posted by BajaSportsmobile
2wd (Stock E-Series) rotors have the hub built into them and are completely different an not what you have.
Thanks Ramsey, I figured that out this morning by looking at a few pictures. So did Dana produce Ford high pinion kingpin Dana 60's that came with 8 x 6.5" disc brakes at any time?.....Or if not, is it possible that my axle has Chevy spindles since it's 8 x 6.5"?
.......I'm trying to determine what rotors are on my van. I communicated with another member here several months ago; he had a very similar van with an Advanced 4X4 conversion and had just done his brakes. He mentioned that the pads/calipers were late model Chevy parts.......I'm trying to determine if my van is similar without removing the rotors and calipers and driving over to NAPA or Orange Engine.
....and I'm also curious about fitting larger rotors......which now does not appear do-able unless someone makes some 13.5" rotors that would fit a kingpin Dana 60 and I would need to design & fab new caliper stands.
