Old 11-03-2021, 11:50 PM   #21
This is pretty much the same bar they use for the Mustang and mine broke the same way. With the exception of the rust
Lairon is offline   Reply With Quote
Old 12-11-2021, 12:04 AM   #22
SierraHawk's Avatar
Death wobble will shear almost anything in front of the trans like engine mounts. Contact Peter DelToro to order a Fox steering stabilizer. My rig had over 250,000 miles on it when I experienced the first death wobble. Ordered the Fox steering stabilizer/dampener the next day. Anyone driving one of these vans or any rig that is modified and equipped with oversize tires should ask for a steering stabilizer for Christmas. The damage and possible loss of control will be much more expensive. Easy to install and can be done in the dirt without a jack. Use a 1/2 inch drive and 18" breaker bar.
SierraHawk is offline   Reply With Quote
Old 12-13-2021, 05:27 PM   #23
Death wobble can primarily occur when there is steering geometry issue, or when there are worn or loose steering related items. A steering stabilizer does not fix anything, it just hides the issue. A steering stabilizer can smooth out steering inputs due to road conditions, but if you have death wobble, take the time to diagnose and correct the underlying cause.
Tan Hot Dog
Jsweezy
Dusty
capnkurt
