You would have to get your Van weighed (truck scales) to find out where you are at, but it sounds like you are well within range for those tires.
Personally I’ve tried other brands over the years (BFG, NITO,), but found TOYO’s to be the best. I run the MT’s because they notoriously require less balancing weight and Have good tread wear (as long as you keep FE alignment in check.). My Van weighs about 11,500lbs, so I have to be cognizant of load ratings, this also limits my options.
