Originally Posted by winnievan
Also -- how'd you go about modifying your tranny crossmember?
This may not apply to you with the 4r100, but this is how I made the crossmember work for the 4r70.
I ended up cutting the curled up ends off my existing crossmember, right where the curl starts, to have as much remaining length in the center as possible. I bought a couple pieces of steel plate from my local machine shop. If I remember right, they were 9”x6”x3/16”. Next, I cut the ends off what was left of my crossmember at new angles so that when reattached, they would clear the front driveshaft and make room for the exhaust. I drilled matching holes in the plates and MG brackets, and bolted the plates up so that I could weld the ends of the crossmember to the plate. The center piece of the crossmember was supported in the right place by the trans mount/trans so that I could hold my new-angled pieces of crossmember in and tack them to the plate and the center cross-member section. Then carefully unbolt all that mess and fully weld all the joints. I put some gussets for strength at the intersection of the cross-member and plates. Be careful not to warp everything with welding. Paint, then put everything in the van.
It probably cost me less than $20 for the plate. I cut the corners off the plate to make it line up nice with the bracket. I also had to do some creative grinder work to clear the bolt.
Fortunately, it seems with the 5.4/4r70 combo that the trans mount is pretty close in-line with the radius arm pivot points. That meant that my angle cuts were limited to changing the up/down angle of the crossmember. It was kind of a crazy setup running the chop saw with the crossmember at the necessary angle, but I made it work. A few pics attached, ignore the welds....it was laaattte at night when I got to that.
Regarding the single tone ring in the van and earlier truck axles, yes, one sensor handles both wheels. It has to if you look at the way the brake line comes in, there is only one running from the ABS pump to the back by the axle.
