Old 03-10-2020, 11:54 AM   #241
Originally Posted by b. rock View Post
Brake question - for a 2013 SD axle, I see that the factory rims are usually 17". Is that the minimum rim size? I'm always a fan of less rim and more rubber.
Some 17s fit no problem, some I've seen are a little tight and require some of the casting ribs on the caliper to be ground down. There's not much chance of a 16 fitting over the larger brakes.
Old 03-10-2020, 12:13 PM   #242
b. rock's Avatar
Gotcha. Sounds like 17s it is then. Thanks
I'll search around, but I'm assuming we need a different offset than the trucks?
b. rock is offline   Reply With Quote
Old 03-10-2020, 12:18 PM   #243
Truck wheels work just fine on the vans. Lots of folks have used factory Fseries wheels.
Old 03-10-2020, 03:57 PM   #244
Houstonredrider's Avatar
Originally Posted by mikejana View Post
Interested in taking this project on. I have a lead on a 4.10 axle out of a 2016 cab/chassis with 40kish miles. I'm told the hubs are different but think it may be easier to swap hubs, than it is to regear.
I'd appreciate opinions.
I got my axle from a 2008 Dually. The scrap yard took the dually spacers out. The difference was that the studs are M14 but coarse thread and slightly shorter that the single wheel. I didn't know and stripped the threads. By the time i was to change the lugs, I decided to put new hubs (new bearings).
If you want to put spacers, the shorter studs will work great, just mind using the proper nuts.
2010 E350 4x4 MG Coil conversion
Houstonredrider is offline   Reply With Quote
Old 03-12-2020, 06:37 AM   #245
Ready for pick up!
I just received good news, my motor is ready for pick up!! Going to get it today after work.
Megalovon is offline   Reply With Quote
Old 03-12-2020, 12:52 PM   #246
mk216v's Avatar
b.rock,
I have 5 of these, brand new in the box!
https://www.methodracewheels.com/pro...=8428848939044
Method Trail(701)
8x170mm
17x8.5
0et/4.75"backspace
BeadGrip technology!
A vehicle’s worth is not what you put into it, but what it put into you.
2019 F350 SuperCrew flatbed composite camper
2018 Transit 130WB MR EcoBoost (SOLD)
2010 E350 RB V10 Cargo "unicorn" (SOLD)
2007 E350 4x4 "VANdiana Jones"(SOLD)
mk216v is offline   Reply With Quote
Old 03-12-2020, 01:02 PM   #247
mk216v's Avatar
Dayumm!!!!!!!!!!
Old 03-26-2020, 09:54 AM   #248
Getting ready to install the MG kit on my 1998 E350/Airstream B190. This install thread is pretty good. Has anyone done a video of the install? The brackets and info provided by MG seem pretty straight forward. I could use some clarification on how the hardware gets allocated.
Can anyone clarify the how/where the M20 bolts for the lower spring keeper are used?
How does the Ford steering stabilizer bracket F2UZ-3E652-A mount?
I will try to document my install and add these tips into some form of installation directions for the kit.
Thanks,
Tom
TXTOM is offline   Reply With Quote
Old 04-15-2020, 06:59 PM   #249
Originally Posted by mgmetalworks View Post
^^^ Yeah...considering that I designed all of the brackets around the installed height of the cc880s springs, I'd say start there. They work really well on most vans.
I put a set of super heavy springs in the Cummins van (5000lbs springs)
https://www.truckspring.com/suspensi...450-Super-Duty
They are a little stiff, maybe because they're new and not a lot of miles yet. Ride is firm but not too jarring...but they're the only spring that holds up the hefty Cummins/Allison at the right ride height. If you have a very heavy rig with heavy steel bumper and the CC880S isn't cutting it, these SSC-31 work well.
I know the CC880s springs a variable rate but how does that rate compare to a stock E350 spring (say for a 7.3 van). And then how it compare to the SSC 31 MG used on the Cummins build (5000#).
Old 04-15-2020, 09:40 PM   #250
In the service manual I think there is a chart of springs and spring rates. I know I’ve seen it somewhere like that. Maybe it’s in the body builders info.
I have the Moog catalog in a filtered spreadsheet if that would be helpful.
